Questions for B2650 owners.
   / Questions for B2650 owners. #1
jrepp44
NW Louisiana
Kubota B2650HSTC
I just received my new B2650HSTC (1.7 hours). The noise from the hydro system is unbelievably loud (low-mid-hi range), I mean you could hear this thing a mile away. I previously owned a L5030HSTC and the hydro noise was very low. I will be contacting the dealer but I wanted to hear what other owners have to say.
   / Questions for B2650 owners. #2
Is the brake on.
Sent from my iPhone using TractorByNet
   / Questions for B2650 owners. #3
Like Sandyc said...is the brake on. More than once I've driven of with the brake pedal latched..Mine (B2650HSDC) makes a lot of noise until the hydro tranny warms up. I note that you have only 1.7 hours and presumably the dealer put some on before delivery..Give it a good workout to warm things up and see if the hydro whine diminishes once the transmission is hot...mine does.
I am positive the brake is not on. This thing is so loud I have to use noise cancelling headphones.
   / Questions for B2650 owners. #5
Could it be air in the hst? I would get the dealer involved asap
   / Questions for B2650 owners. #6
Only time my hydro is loud is in hi range. Low and mid are fairly quiet, though mid can get a little loud trying to push it a little too hard.
I'm not sure if these work like a riding mower transmission - but idle the motor down and put it in neutral. Slowly work the pedal from full forward to full reverse, holding it at the full point for 5-10 second periods. Do this a half dozen times or so, should purge the trans...... IF these work the same as a riding mower. Shift back into range and see how it sounds. Pretty sure that's not going to hurt anything doing that, worth a shot. That's all I got for ya.
   / Questions for B2650 owners. #7
Is it brand new? I would try one out and the dealer to see difference then I would check to make sure it has sudt2 fluid
   / Questions for B2650 owners. #8
My 2620 "howls" when you lug it in high range. When that happens I either switch to a lower range or let off on the go pedal
   / Questions for B2650 owners. #9
As a follow up, my 3350 howls louder thn the 2620. I think it is the cab that captures the sound and amplifies it. Blowing and plowing snow next winter is going to be worth it with a cab that is warm. Guess I'll just turn the music up louder.
Thanks for all the replies. The dealer has picked up the unit to look at it. I will let you know what they find out.
BLAST SHIELD (A50854)
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
