questions during hydraulic fluid change
   / questions during hydraulic fluid change #1
unclesalty
Hudson Florida
09 ct-225 w/loader
Well its time for my hydro maintenance. The short story..Dipstick said the level was good. I drained from all 3 plugs and only got 5 gallons out after at least an hour draining. I filled the 1 filter up and screwed them both on and poured in the new oil. I was just able to get 5 gals back in and the dipstick shows slightly over full. The manual says it should take 8 gals of fluid. should I be worried? (the loader was down all hydraulics were retracted). Im kind of tempted
to run it up to temp and drain and fill again esp if there is still 3 gallons still inside. The old fluid was nasty. Tractor was at 700 hours but its 9 year old fluid so I changed it out early.
   / questions during hydraulic fluid change #2
did you fill your filter?? if not then thats why you are over full . run it a few minutes then let it set and recheck
   / questions during hydraulic fluid change #3
If you have a mid pto you have 4 drain plugs, one on the pto case.
   / questions during hydraulic fluid change #4
Even if your cylinders are retracted they still hold a fair amount of oil.
duh I had assumed the rear pto had replaced the 3rd plug...Looks like I'm off to get another bucket of fluid.
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A55315)
2018 Cadillac...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
John Deere 1025R (A53317)
John Deere 1025R...
