questions during hydraulic fluid change
   / questions during hydraulic fluid change #1
unclesalty
Hudson Florida
09 ct-225 w/loader
Well its time for my hydro maintenance. The short story..Dipstick said the level was good. I drained from all 3 plugs and only got 5 gallons out after at least an hour draining. I filled the 1 filter up and screwed them both on and poured in the new oil. I was just able to get 5 gals back in and the dipstick shows slightly over full. The manual says it should take 8 gals of fluid. should I be worried? (the loader was down all hydraulics were retracted). Im kind of tempted
to run it up to temp and drain and fill again esp if there is still 3 gallons still inside. The old fluid was nasty. Tractor was at 700 hours but its 9 year old fluid so I changed it out early.
   / questions during hydraulic fluid change #2
did you fill your filter?? if not then thats why you are over full . run it a few minutes then let it set and recheck
   / questions during hydraulic fluid change #3
If you have a mid pto you have 4 drain plugs, one on the pto case.
   / questions during hydraulic fluid change #4
Even if your cylinders are retracted they still hold a fair amount of oil.
duh I had assumed the rear pto had replaced the 3rd plug...Looks like I'm off to get another bucket of fluid.
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
CFG Industrail MX15RX (A53317)
CFG Industrail...
Informational Lot - Financing (A56435)
Informational Lot...
M998 (A55852)
M998 (A55852)
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
