Questions about Iseki TA 320
   / Questions about Iseki TA 320
OK. I've found glow plugs on eBay. And even a complete kit to rebuilt the engine. It's good to know it.
Yes. The advantage on this loader is you can remove bucket to use forks. I don't have forks on this loader, but I'll make soon.
   / Questions about Iseki TA 320 #14
It's a beautifull tractor. And if you have the clim, it's usefull for you. Here in the north of France, it would be useless ;).
   / Questions about Iseki TA 320 #16
Has air conditioning and heating, although the heating here in Portugal is not lacking much
   / Questions about Iseki TA 320 #17
You might want to investigate if your existing glow plugs are actually "bad." Test their resistance for being open or shorted. They should have around 1 ohm of resistance. You mention the glow time is long - how long? Typical glow times are 20-30 seconds. If you're missing the glow indicator or it is broken the glow plugs will not function unless someone bypassed it.
Thank you for your answer.
Edit: glow indicator works, but spring is at the bottom, and seating it's not very viewable, but it works perfectly.
Actually, with a rather hot weather, glowing time is typically 10 seconds. But in winter, it's longer.
But glow plugs are not expensive and I'd prefer to have 2 pairs in replacement. I've tested glow plugs with z 12V battery. They became red more or less quickly.
Two questions for this kind of tractor owners: are they springs Under the seat ? Mine don't have them and it's not confortable.
Could someone post a picture of fuse box ? I don't have the cover anymore.
Thank you.
Hi !
Another question: what is it ?
I'm very happy with it, it's very usefull.
2017 Genie GTH-5519 (A53317)
2017 Genie...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2017 BOBCAT T650 SKID STEER (A52707)
2017 BOBCAT T650...
30008 (A53424)
30008 (A53424)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
5 pcs. (A55852)
5 pcs. (A55852)
