Questions about hyd angle front plow
/ Questions about hyd angle front plow #41
LBrown59 said:
There are threads about fel mounted blades here .
I was reading them recently.
Don't know where right off hand but you can do a search.:)
Thanks...I read the hole tread now ;) The FEL snowblade idea didnt sound like a good solution:confused:
I have my Suzuki Kingquad 700X with Warn snowblade and chains, work really great, but want to use the BX with hydralic angle snowblade:D
/ Questions about hyd angle front plow #42
The problem with this deal is when ya need the bucket ya have the blade on and when ya have the blade on ya need the bucket.
Switching these back and forth out in 10'' of snow on a 10 degree day ain't my cup of tea.
So I'm putting a front blade on a BX1500 and leaving the fel and bucket on my BX23.
No playing musical implements that way.
/ Questions about hyd angle front plow #43
AMR said:
Zick:
I plowed two seasons with my bx23 and 60" blade. It rocked!
Everyone has a unique situation but for me it was perfect, about 500' of drive up to 13%. No problem. I left my BH on for ballast and never had serious traction problems.
We did have an 18" storm, it took several passes but it got the job done.
For mounting, I would say realistically about 10 minutes, I drop the blade on a dolly and disconnect, about 1 minute in time, and then take the quick hitch off, that takes the other 9 or so.
I just traded by 23 for a B3030, I got the 72" blade for that.
Good luck,
Alan
I have the same blade on my BX1500.Nice and would be more nicer if the blade would lift a bit higher.
Set of 4 Forerunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Set of 4...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
LOT OF 2" SQUARE TUBING (A64278)
LOT OF 2" SQUARE...
2016 Ford F-550 4x4 ETI ETC37IH 37ft. Insulated Bucket Truck (A64556)
2016 Ford F-550...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
