Grapple questions about choice of root grapple
   / questions about choice of root grapple #61
Deerherd said:
I’m getting the 60” model. It’s more important to me to be able to clear the width of the tractor than how big a root ball I can dig with it. I will never be trying to compete with you guys! Plus it gives me a pretty good idea if I am going to hit the CAB! Ninety-five percent of the time it will be carrying, not “grubbing” so that’s the right style and width for me. A friend has the 48" WildKat and short of a quick attach problem that he welded on some shims for, he has been pleased. Many on here are more than happy with theirs.
I just felt the MIE, though more expensive is a better unit suited well to my needs and I liked the people. They answered all my questions, it was shipped on Tuesday and arrives tomorrow. Plus it already painted the right color……:)
QAG60S Hound Dog Attachments Grapples Single Top Grapples
That is an interesting hybrid design. Certainly looks well built. I wonder why they chose to use such short bottom tines? Looks very sturdy but will probably not have quite the capacity of a more traditional OBG/Millonzi/Markham/Wildkat nor will it dig as well. Really solid though.
   / questions about choice of root grapple #62
I read the same posts. That was one reason I bought the GATOR... North American Implements. These are pretty solid units and the Econo's come in either 48" or 60" for about the same price as a WildKat.
Which grapple did you get from them?
   / questions about choice of root grapple #63
Red Horse said:
I have to second Whitedogone. The 48 Wildkat should be perfect for your machine. I have a 4720 (60HP) and it works very well. With 60 horse could I wreck it? Probably but common sense keeps me out of trouble. Great value. I use it for brush, bucking logs and its handled its share of stumps. One of my kids has it now on his 2520 doing clean up-check my avatar and attached pix as I ordered it without Deere hooks and put my own on.
Why did you decide to add your own Deere hooks? Was it price or quality or what?
   / questions about choice of root grapple #64
foggy1111 said:
You can take IT's recommendations to the bank. But....I aint so sure he's picked up the biggest ever load of brush.....I gotta dig thru my pics......I didn't know there was a contest. ;) :D
Sometimes I pick up whole pine trees.....and if not balanced right....I get concerned about twisting the loader. Some of those trees can be pretty heavy and there is allot of leverage. Short sections like shown here are no big deal.
Which model grapple do you have on that green machine?
   / questions about choice of root grapple #65
Thanks, smilinjak. I appreciate the info. I have looked at the CA 60. I think I have settled on the W. R. Long 56" or 48" version. The Long 56" is very similar to the CA version, for about the same price, but it has a 44" jaw opening, plus I won't have to mess with the hydraulics because our FEL has a Long 4N1 bucket with presumably identical hydraulic hookups. You definitely have my attention about rear wheel spacers. I tried to look up Tracks Co on the Internet and couldn't find them, so I'll call or email. Our L3800 is a hair over 60" outside to outside on the rear wheels. We traded in a Kubota M5400 on which I had both the front and rear wheels set to the maximum width for stability. The L3800 doesn't offer any options for more width, so I would be interested in the spacer idea. Do you have the spacers on your 3800? If so, how much width did you gain? I'll follow up. Thanks again.
Rbtjr: I have the spacers on hand but due to wife's illness requiring all my free time for the last several weeks I have not installed them. As for width increase that can be what ever you want, from 2 1/2 inches up in 1/2 inch increments. Christian Hanson can give you some advise on that. He is very patient and knowledgeable. I chose 3 inches as the best compromise for me. Once installed I should have a 66 inch rear tread width. Not so wide as to over stress bearings or castings in the rear drive housing but wide enough for stable footing on my varied terrain. Also gives me clearance for chains when we get snow. My driveway is 12% grade and even loaded R4's don't grab our wet snows very well.
You are going to like that grapple! !
Smilinjak
   / questions about choice of root grapple #66
Ted from everythingattachments.com has a youtube showing
his wares in action. That is about it on YouTube. I would love
to see some real world grapple usage in real word conditions.
Not just picking up piles of branches, they all will do that what
I am having a hard time determining is whos unit works best
w/ the front lower tines actually digging into the dirt and
ripping out "Roots" .
You can also order ours to match your tractor!!
Here's the video. It's more costly than some others on the market, but you'll appreciate it over time!!
   / questions about choice of root grapple #67
I also made a video with a more in-depth description for you guys.
   / questions about choice of root grapple #68
I've got a 48" Gator....that was built right when Gator was taking over Markham (I thought I had bought from Markham).
One thing about all these models from Gator / Markham / Wildcat or the predessors....is to MAKE CERTAIN they install the JD QD attachements correctly. Mine did not have the gussets to properly support the top hooks and I lost my grapple as a result of the hooks opening and damaged my loader to the tune of a few hundred dollars. I see lots of other folks without the gussets too. BAD NEWS!
The JD 300cx loader can really lift and those long tines really apply some pressure to the mounts.....MAKE SURE YOU HAVE THE JD GUSSETS INSTALLED if you buy a JD QD grapple from these companies. Look at any John Deere bucket to compare the gussets at the top hooks. You have been warned!!
   / questions about choice of root grapple #69
Very helpful warning. You stated, make sure the JD QD is installed correctly. How was it initially installed and what did you have to do to correct it? It would almost seem that if Gator doesn't know what they are doing, don't order this product unless I want to have it modified before I use it.
On another note, that may be the reason why others have opted to order without any QD and install their own. Seems like the manufacturer would get the hint.
Thanks again
   / questions about choice of root grapple #70
Video Link: http://youtu.be/-moXcIklQpU
Nice video and well constructed grapple. However, why is 66" the smallest size you offer when other manufacturers sell 48" versions that are well accepted by the CUT community? As you must know if you have read this thread, there are significant advantages to a lightweight 48" size single arm grapple especially for tractors under 40hp and even for larger CUTs. Your offered sizes show these are really just knock offs of skidsteer grapples with little thought given to the differences in how CUTs and skidsteers are used. Why not give your customers the choice of an identically built narrower version with a single upper arm? Use the same templates etc etc just make it narrower. If you outsource this grapple from Construction Attachments (who have far more skidsteer focus and treat the CUT market as an afterthought), why not ask them to build you a "CUT special" 48" version. The bottom half of your current grapple is identical in construction to my 48" Millonzi and your upper arm is much improved over mine. Make up a prototype and I'll test it for you!!!
Your business is better organized and marketed than some of the other 48" grapple manufacturers so there is an opportunity out there to exploit. Build a better 48" light duty and you'll add jobs for the economy. It's your patriotic duty!
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
Case IH 875 Disc Ripper (A59814)
Case IH 875 Disc...
Sprayer Cart (A59228)
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
King Kutter XB 3pt Mower (A59814)
King Kutter XB 3pt...
