Questions about buying a B3030 with 63" snowblower
   / Questions about buying a B3030 with 63" snowblower #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
Looking at a Kubota B3030 and wondering what the feedback is on this model?
It comes with a 63" snowblower. Can someone tell me if it has a hydraulic rotation kit
that is listed on the Kubota site?
Any idea as to resale value on this blower?Has been used and has some rust and some
Here is a photo of the side wall of the rear tire. What is your opinion of the tire condition-checked, damaged?
Thanks.
   / Questions about buying a B3030 with 63" snowblower #2
Good solid Kubota tractor, how many hours? The snow blower in the picture you posted is a hand crank unit as you can see the hand crank on top od blower. The tires look ok to me, hydro kit can be bought to make it hydro rotation but it will be expensive if you don't install yourself.
DevilDog
Am I correct in assuming that it will simply move up and down the way this blower is outfitted-no side to side movement?
Is the newer model 3350 with 33 HP a Tier 4 tractor?
DevilDog
   / Questions about buying a B3030 with 63" snowblower #4
Yes the hydro lifts the snow blower up and down, the long hand crank will turn the snow shoot left & Right. And yes it's my understanding that any 30 horse tractors and above are tier 4, Def,dpf. Others will say that they have no issues with them but others will say they had many issues. I use to own 1 ton Diesel pickups all of the big 3, now I own a 2016 2500HD Denali Gas too many issues with them 1 ton Diesel trucks too, but each to their own, good luck tractor hunting.
DevilDog
   / Questions about buying a B3030 with 63" snowblower #5
DevilDog
Yeah, I was going to put one on my Kubota snow blower 10 years ago and the dealer wanted around $600.00 back then.
   / Questions about buying a B3030 with 63" snowblower #6
Thanks for the information.
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A49461)
2021 Fleco DX140...
Lift Station Pumps (A49461)
Lift Station Pumps...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
