Questions about BCS 38" mower?
   / Questions about BCS 38" mower? #11
Locking the Diff isn't a good method and i would doubt he's ever mowed a hillside if he gave you that idea. Once you lock the diff, you cannot easily make any adjustment to direction. Even with both tires driving, it will still wander downhill - though maybe a bit slower (yes, I've tried it).
Running a 732 will not help you in your decision unless it has had brakes installed. The 732 does not come with brakes.
The 18 inch tiller is 18 inch only. The larger tillers have the same gearbox. You can get a 20/26 tiller or a 26/30 tiller. If you buy a 20 inch tiller now, you can buy extensions later and make it a 26 inch. This is an expensive way to do it as the hubs are something like $75 each. If you think you'll need a larger tiller in the future, you'd be better off buying a 26 inch tiller and making it a 20 inch. You can hang the hubs in the garage for later.
farmerboybill,
Thanks for reminding me about the 732 not having brakes. I guess if I do test drive this tractor/mower combo it would be a worst case senario. I'll bring that up when I talk to the dealer later in the week. I bought a small Kubota tractor a few years back and it was no problem to take one for a short test drive and get all of my questions answered. It has been just the opposite with this (possible) purchase. If it wasn't for this forum I think I would have walked away from BCS awhile ago. I still haven't gotten a straight answer on a wider tire option (tires they show in their sales brochure).
Thank you for answering my question on the tillers though. I doubt I'll need anything larger than 20". I have an 18" tiller now and it gets the tilling done in about 10 min. I was just worried the gear-box may have been lighter duty or missing some feature on the smaller one. Tilling will be the least of the jobs for this equipment. Mowing will be the most used with wood-chiping a distant second (possibly a snow-blower in the future).
Thanks
   / Questions about BCS 38" mower? #13
That is pretty disappointing the dealer won't get you a demo of what you want to buy. I sold a Grillo G85 to a Mennonite last week. I took the machine right to their place, gave a demonstration on running it, and let them all try it out right in their own garden. Up 'til that point, no agreement had been made. They coulda sent me home with my machine with a "Thanks for tilling our garden"
As far as tires go, check out Earth Tool's offerings -
Tractor Accessories
You might need to buy two sets of tires if you want turf tires for mowing. I don't think you'll be able to get them to fit in the tiller width.
   / Questions about BCS 38" mower? #14
Let me preface this by saying I have only mowed with my grillo a couple times . I have mowed a lot with a gravely 2 wheeler. On anything other than flat level ground I do less damage to the grass with tractor tread tires than turf tires tractor tread grips and goes where turf tires spin and tear up the grass . this is just my personal opinion your milage may vary .
Roy
   / Questions about BCS 38" mower? #15
DSC02605.JPGThat really is disappointing to hear about your dealer Cent PA, usually most owners and especially dealers love to promote these little tractors for all they are capable of. I can't imagine why they won't accomidate a request for a trial - most equipment dealers are more than happy to do one.
As for the slopes, I have several sections that are fairly steep and just feather the correct brake as needed to keep the tractor running in a fairly straight line. I too have tried the diff lock, but find most of the time the brakes are less hassle.
As for the tiller, my sugestion is to go with the 26" and just remove the extensions if you don't need them. You may want to increase your garden area once you see how easy these tractors make soil preperation.
You should have no issue getting rid of your existing mower and just using the BCS & string trimmer for the yard. I cut around everything with the 38" mower and just clean up with a string trimmer, no sweat. The mower REALLY does a nice job on the grass, you won't be disappointed. Best of all with the quick disconnect it is easily removable so you can wash the underside to keep it from rotting out after you cut. I have attached a picture of my 735/725 (I combined a 735 transmission & handlebars with my 725 tractor to make a 735) and the 38" mower. Good luck with the purchase - I'm sure you will find it a very worthwhile investment.
farmerboybill,
I've been on the Earthtools website. He has a lot of good information on there. From everything I've heard he's very good to deal with. I'm just a little leary of buying such a large and expensive piece of equipment mail order. I'll be doing my own maintenance but if there is a warranty issue (more than a 30 min fix) I'll expect it to be taken care of. That would be quite a hastle if I have to have a tractor shipped back. As for accessories or even an attachment I would certainly consider Earthtools.
plumberry,
Thanks for the advice on the tires. Mowing is what I'll be doing the most. I was figuring that a wider contact patch of a turf type tire would do less damage but with a piece of equipment that light turfs just may not have enough "bite". My other thought was a future snow blower would require chains for my steep (~15% average, 18% max) driveway. I wasn't sure how well chains will work with ag tires. My experience has been with small compact tractors. I had one with the industrial bar tires and it didn't do any favors for the lawn. They weren't that good in the snow either. I now have a small Kubota with turf tires and they have done well in all but mud. In the snow with chains on the rear it's done a great job.
mpapiary,
Thanks for the photo of your mower set-up. I appreciate the feedback on the mower. There's not a lot of information out there on them (customer generated). I'm glad to hear it can be used as an only mower for a lawn. I figure between stramlining my yard and getting used to using a larger walk-behind like this BCS I should be able to ween myself off the lawnmower.
I'll let every one know how it goes.
Thanks again for all of the replys.
   / Questions about BCS 38" mower? #17
Hi,
I am a new member here and just regested because of this thread. I have been looking at getting a 2 wheel tractor for my property. Around my home I have 1/2 of grass to cut with many trees (15). I also own a hunting camp ( 50 acres) where I have 1/2 acre around a camping area including a berm around a pond, many grassy trials and about a total of 3 acres of clover food plots. I would like one tool to cut my grass at home and at camp, snowblow in winter and mow my clover plots. My only issue is I would like to mow the clover at about 8" hight. Can any of the attachements mow at a high of 8"?
Thanks,
Bob
   / Questions about BCS 38" mower? #18
Hey Bob,
Sounds like you want a sickle mower. If properly balanced to the engine, it will mow at any height you want to hold it, or you could modify the skids to keep it 8 inches off the ground. A sickle mower would also do a good job of mowing trails once a month and mowing the pond berm a couple times a year. It's very nice for mowing a pond edge because the sickle sticks out past the wheels and can safely get weeds growing in the water. Keep in mind a sickle mower will only cut off the material and leave it lay. It will not grind it up.
With a wider sickle mower and oversized tires, you should be able to do 1/2 to 3/4 an acre per hour. This is considering you have obstacles. If you were mowing an open field and are fit enough to maintain an ~3 mph walking speed, you should be able to do up to an acre per hour.
   / Questions about BCS 38" mower? #19
Cent PA
Since it has started raining some I have got to use my g85d with the 28" zanon deck a few times now . I have 4 tenth of an acre , with fruit trees, grape vines , gardens and drive so I mow around half that . It is an obstacle. Only faults , things that stop a self propelled push mower it will run over :D or climb up if the object is solid :shocked:. Even with the slow speeds of the g85d it is quicker than my push mowers. If you let the grass get a little heavy it doesn't bog it down. My last push mower went out of here via craigslist last week.
Roy
plumberroy,
Thanks for the feed-back on the mower attachment. I got a chance to take a brief try at a BCS 732 (no brakes) with an old 38" mower. I can see your point about it running over things if you're not careful. It's a bit of a beast compaired to a push mower. It did handle better than I thought it would though. On level ground it was no problem at all to control. On hills it wanted to dive down as I tried to mow across (cross-slope). I've been told here that won't be a problem with the 740 I'm looking at (using the brakes). My local dealer still has not done anything to get me a test drive of one with a mower. I've about given up on him and have gotten a quote from Earthtools. I'm seriously thinking of going that route. I'm still a little worried about getting such a big and expensive piece of equipment mail order though it looks like Earthtools has a very good reputation here and other places I've read. Did you get your Grillo from Earthtools. Any issues?
I'm glad to hear your mower is working well for you (and can get rid of the old one). That's the same direction I want to head.
Thanks
2016 R and R Products 331 LP Reel Mower (A51691)
2016 R and R...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53472)
Mitsubishi FG35...
2021 John Deere C12R Corn Head (A53342)
2021 John Deere...
Year: 2017 Make: International Model: DuraStar 4300 Vehicle Type: Truck Mileage: 45,026 Plate: Body (A51692)
Year: 2017 Make...
2021 Simex TFC 400 rotary cutter, like  new (A52384)
2021 Simex TFC 400...
