Questions about B3030
/ Questions about B3030 #1
Rolando
Platinum Member
Northcentral Florida
Bobcat Toolcat High Flow Turbo C-series
I was reading about the Mid-Mount Mower on the Kubota web site and I wanted to ask if anybody knows what this feature means:
"The 72" deck has the drive-over feature for easy installation and removal"
Also, does anybody know what the height of the Cab model is? Kubota is still not listing any information about it.
/ Questions about B3030 #2
The drive-over feature means that to install or remove the mower deck, you don't need to slide the mower from the side. You simply drive over the deck with the front wheels. Nice feature to have with a deck as big as 72". I can't answer about the cab height.
/ Questions about B3030 #3
They don't post heights because it varies depending on what tires you use. Once they are available I am sure someone will measure one.
Then let me re-phrase that. Is it possible that it would be taller than 8 ft.? I'm going to put in 8 ft. tall garage doors, which would be okay for the ROPS, but I was wondering if the cab would be a lot taller than that. And if I'm going to get one any time soon, I'm thinking I need to order one now, sight unseen.
Maybe someone could provide input on how the ROPS height compares to Cab height on other models that have them, like the L3430?
/ Questions about B3030 #5
My B2910 FROPs is 90" with turf tires. On Deen Implements site they show a picture of a Cab and Standard ROPs tractor next to each other. 8' maybe close. If your garage can have a 10' door put it in.
Thanks for the reference, Ron, that's a good comparison side by side. They're showing a fixed ROPS and I understand the FROPS is taller, although I don't remember by how much. I'm wondering if that might make the cab model about the same height as the FROPS.
I'd hate to have to go to a 10 ft. door, that would mean making the ceiling height 11 or 12 ft., which I would not have normally done.
By the way, do R4 tires (bar tires?) make the tractor taller than the turf tires? I've been thinking that since I'm looking at a lot lighter tractor than the L3130 I considered initially, I might go with R4's for better traction during construction of the house.
/ Questions about B3030 #7
I believe the R-4's are a little smaller than than R-3's.
I know your are doing a garage. But I'll put my 2 cents in anyways. When I built my barn I debated whether to make it 8' or 10'. That was before I bought a boat. I did go with 10'. A few years latter I decided to buy a 28' boat. I was able to get into the 10' barn by removing the tire and wheels and installing some 14" steel rims without tires. Marked up the concrete floor. But I was able to get boat in. I should have been deciding when I built between 10' and 12' and gone with the 12'.
When my neighbor built his new barn/garage I and others recommended that he make it 12' high. Since they have the desire to buy a Motor Home. They have not bought a Motor Home yet. But the barn looks great with the 12' X 12' roll up doors on either end.
/ Questions about B3030 #8
Howdy,
I wrote to Kubota and they informed me that the tractor with largest tires is 84" high with Cab. That means that if you have a 7' garage door opening you will need to put a little butter on the roof to make it fit. Bummer.
Jeff
/ Questions about B3030 #9
</font><font color="blue" class="small">( By the way, do R4 tires (bar tires?) make the tractor taller than the turf tires? )</font>
Nope, Ron is correct - the height of my B2910 with FROPS/R4's is just about 84.5" - just a hair too tall to fit thru either the overhead door on my shed or the garage.
I would definitely go with a taller door if I were you - nothig worse than investing a bunch of money in building something ony to find out later that your equipment won't fit in it. FWIW, our garage has a 12 foot ceiling - but due to the roofline/slope they only put in a 8' door - sure wish they had put in a larger one when the place was built.
Randall, I must be missing something. An 8 ft. tall garage door, which is what I'm planning on, will have a clearance of just under 96". So wouldn't an 85" tall tractor go through it just fine? The ceiling will be either 9 or 10 ft. tall.
/ Questions about B3030 #11
One thought you may want to consider as you design the garage: There may be times when you want to lift an implement, remove an engine, or partially lift that mower deck so that you can remove and sharpen the blades. A hoist comes in very handy for this purpose. One of the bays could be spanned by a heavy duty lifting beam, supported by strong support posts at each end. You could then place a chain hoist or an electric hoist in the center of the beam. This would allow you to lift implements and set them on dollies, remove an engine, or access those blades for sharpening.
I have a 3 car garage. The BX stays in one of the bays as well as all of my implements which are on dollies. When I need to change implements, the 2 cars come out which leaves plenty of room for rolling the dollies around. This is especially helpful for rolling the MMM under the tractor. It is so much easier to attach implements to the 3ph when they are on dollies that can roll on a smooth concrete floor. If you can afford it, I'd highly recommend having a large enough floor to store implement dollies and roll them to the 3ph.
/ Questions about B3030 #12
In my limited experience, go with as tall a ceiling height as possible. My new garage was limited to 10' finished ceiling by code, so I couldn't put in the 12' that I wanted. /forums/images/graemlins/frown.gif I wanted 12' for a 10' door just for the reasons being discussed here. I only have a 8' door now.
My Garage
/ Questions about B3030 #13
if i was building a new garage 8' would be the min. i would go 9' at least. it really does not add that much more to the cost. i have 7' doors /forums/images/graemlins/frown.gif everything fits but just barley.
/ Questions about B3030 #14
</font><font color="blue" class="small">( Randall, I must be missing something. )</font>
Nope - it was me (still in a fog from almost cutting off the tip of my thumb on the bandsaw this weekend /forums/images/graemlins/shocked.gif Didn't hit the bone and it only required 5 stitches but it still hurts like heck /forums/images/graemlins/grin.gif)
My doors are actually 7' - I was thinking they were 8' so you should be good.
/ Questions about B3030 #15
My L4610 HSTC with R4's is just over 84" tall.
Thanks, Randall. And I think I'll put off that bandsaw purchase... Hope you get to feeling better soon.
/ Questions about B3030 #17
</font><font color="blue" class="small">( And I think I'll put off that bandsaw purchase... )</font>
Nah ..... don't put it off - they're incredibly handy tools.
..... just make sure you hang the attached sign next to it.
  • 586030-SawSign.pdf
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
2021 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2021 Caterpillar...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
