question
/ question #21
</font><font color="blue" class="small">( What is position control? I know what draft control is, so what is position control?
Bob )</font>
Position control will bring the implement to a realitive position to the lift handle at the quadrant. for instance.. if you lift the implement to the desired height, and then made a mark with a marker as to where the lift handle was on the quadrant, and then, lifted the lift up full, or dropped it down, and then returned the handle to that mark, when you look back, the implement will be where it originally was...
Soundguy
/ question #22
Bob )</font>
Soundguy
/ question #23
</font><font color="blue" class="small">( What is position control? I know what draft control is, so what is position control? )</font>
My CK20 has a scale of number so that you can hit the same spot each time. The position control only requires that one move the lever to the desired position, and then goes to neutral without having to return the lever manually to neutral.
This system is much more accurate than 1/4" which does just that, moves in 1/4" increments, not as accurate. Having older style is even more work as the lever must be returned to neutral, and trying to hit the same spot each time is much more difficult without putting on check chains at different spots.
With position control, you can set it high or set it low as quickly as you can move the lever to the position, and you're done.
John
/ question #24
John
/ question
i remembered on the way home i dont think i tried the position control on the kubota and massey, it was a cub cadet, i probably assumed the other subcompacts were the same. the cub just had either full up or full down no inbetween.
/ question
/ question #29
</font><font color="blue" class="small">( the cub just had either full up or full down no inbetween )</font>
Wow.. that sounds like a draft mode.. I've not seen any other scut with only up or down as an option.. perhaps it was adjusted wrong?
soundguy
/ question #30
soundguy
/ question
i dont think so, i think it was a cheap imatation of a 3pt setup, im glad to hear the others are not like that because i want to buy one soon. this cub was a gas model. i have a great kubota dealer 4 miles from my house, ill have to see how i like the 1/4 inching thing because i would like to buy from him since he is so close.
/ question
/ question #33
Could you post the model number? I'm only familiar with one modern cub tractor with a gasser engine.. i wasn't under the impression that it had only up/down hyds. I can however, lookup the specs for you with the model number.
Soundguy
/ question #34
Soundguy
/ question #35
I didn't know there was such a thing. Even the 8N had a 3 pt. control that allowed you to set the height of the drawn implement. The draft control raised it up if needed, but then it settled back to where you had it. Mine had a little thumbscrew widget to help you get the exact spot each time, as does my Case.
/ question #36
/ question
it was a 5000 series, i dont remember the exact number 5xxx, but i think it was the only gas model.
/ question
/ question #39
Another neat thing about the CK20 3pt control is that it comes with a screw type "stopper" that you can slide along the track that has the numbering on it near the lever. I love this for snowblowing the driveway. It's gravel and I can't put it down all the way or else it picks up the gravel and rocks. So I set the "stopper" at just above the lowest setting and I don't even have to look down when droppping the snowblower, I just slowly drop the lever until it hits the "stopper" and go. Makes things much faster and safer. /forums/images/graemlins/cool.gif
/ question #40
John Deere 6200 Tractor (A64047)
John Deere 6200...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2014 Fiat 500L Hatchback (A66738)
2014 Fiat 500L...
2016 FORD TRANSIT 350 PASSENGER VAN (A66091)
2016 FORD TRANSIT...
2021 TAKEUCHI TB240 EXCAVATOR (A65056)
2021 TAKEUCHI...
