Question: re: Breaking in new tractor & PTO
   / Question: re: Breaking in new tractor & PTO #1
kco
Armstrong, BC
Kioti DK35 SE HST (2011)
I have 20 hrs on the Kioti DK35 I received a couple of weeks ago. The "work" (i.e. play) has been grading, raking, and using the loader. I have not yet used the PTO.
I got thinking about the 50 hr service and changing all the oil and filters. Should I be running the PTO even if I don't need to? It would help break it in and dislodge any particles that may be around from the original machining. They would be cleaned up with the 50 hr filter change.
I likely will be using mowers before the 50 hr service but thought I'd ask the question anyhow.
   / Question: re: Breaking in new tractor & PTO #2
no if you dont have pto equipment hooked to the pto,theres no reason to run the pto.
   / Question: re: Breaking in new tractor & PTO #3
I think it would be wise to operate the PTO soon to just be sure it works.
You would think the dealer would have checked it but I can tell you for
sure that is not always so.
I tried the PTO on my U-5030 after about three weeks of plowing snow
and it would not turn. Called the dealer and he said, we will check
it out. After getting off the phone I was looking under the tractor and
found the PTO control switch was unplugged. Those conectors have lockes that do not come loose. After plugging it in with a sharp snap, it worked fine. I would say it came that way from the factory.
All dealers should check to be sure everything works but not all do.
Best of luck with your new tractor, hope it serves you well.
   / Question: re: Breaking in new tractor & PTO #4
You want to cause some ware, without a loaded PTO there would be little ware. Run the engine hard, use all the gear ranges and than do the 50 hr service. Torque all the nuts and bolts. If you can, take note of what you find in the filters.
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
