Question: re: Breaking in new tractor & PTO
   / Question: re: Breaking in new tractor & PTO #1
kco
Veteran Member
Armstrong, BC
Kioti DK35 SE HST (2011)
I have 20 hrs on the Kioti DK35 I received a couple of weeks ago. The "work" (i.e. play) has been grading, raking, and using the loader. I have not yet used the PTO.
I got thinking about the 50 hr service and changing all the oil and filters. Should I be running the PTO even if I don't need to? It would help break it in and dislodge any particles that may be around from the original machining. They would be cleaned up with the 50 hr filter change.
I likely will be using mowers before the 50 hr service but thought I'd ask the question anyhow.
   / Question: re: Breaking in new tractor & PTO #2
no if you dont have pto equipment hooked to the pto,theres no reason to run the pto.
   / Question: re: Breaking in new tractor & PTO #3
I think it would be wise to operate the PTO soon to just be sure it works.
You would think the dealer would have checked it but I can tell you for
sure that is not always so.
I tried the PTO on my U-5030 after about three weeks of plowing snow
and it would not turn. Called the dealer and he said, we will check
it out. After getting off the phone I was looking under the tractor and
found the PTO control switch was unplugged. Those conectors have lockes that do not come loose. After plugging it in with a sharp snap, it worked fine. I would say it came that way from the factory.
All dealers should check to be sure everything works but not all do.
Best of luck with your new tractor, hope it serves you well.
   / Question: re: Breaking in new tractor & PTO #4
You want to cause some ware, without a loaded PTO there would be little ware. Run the engine hard, use all the gear ranges and than do the 50 hr service. Torque all the nuts and bolts. If you can, take note of what you find in the filters.
2017 Ford F750 Buck Truck (A52377)
2017 Ford F750...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
CONTAINMENT SKID MOUNTED (A53843)
CONTAINMENT SKID...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
