Forks Question, pallet fork users, which one should I get
   / Question, pallet fork users, which one should I get #1
allen in texas
Platinum Member
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
My tractor is a Grand L5740 with an 854 loader. What capacity, what brand, notched fork locators or sliding bar type? Length of forks? width and thickness. I don't abuse my equipment but I don't baby it either.
Is that enough questions?
Shoot!!! Just noticed a sticky about pallet forks. Guess I'll read all that :D
Ok read the entire thread didn't find what I wanted to know...
   / Question, pallet fork users, which one should I get #4
There wasn't an answer to your questions anywhere?
Buy the stock Kubota forks that are made for the L5740. They are expensive but quite sturdy.
Mine are mostly used for heavy logs but they come in handy for a multitude of uses.
   / Question, pallet fork users, which one should I get #5
Those look pretty identical to my frontier forks...probably made in the same factory...pretty darn sturdy if you ask me...
Sent from my LGL35G using TractorByNet
   / Question, pallet fork users, which one should I get #6
Try and find an ANSUNG dealer. I have their Terraforce 42 inch for my Bobcat CT235. Perfect match. You do not need much more capacity in the fork than you can lift. The ones I have are the sliding notch type. Best investment I have made yet.
The best suggestion I can make is visit you local AGG dealers that rent equipment. Looks at the brands they rent and the sizes they recommend for your tractor. I got a sweet deal on a used set.
Hope this helps
   / Question, pallet fork users, which one should I get #7
I prefer the sliding bar type, because on uneven ground the tips are free to be at different heights. P6190005.JPG
I put a chain around one or both forks for dumping brush or trees.
They are 42" long, but I am looking for longer ones.
   / Question, pallet fork users, which one should I get #8
I second the sliding bar type.
I was raised on the sliding bar type and find them much more versatile.
My tractor came with the notched bar type and I really don't care for them. I would like to replace them with the sliding bar type.
   / Question, pallet fork users, which one should I get #9
I vote for the notched bar (non floating) vs the bar type (floating).
The round bars are too easy to bend. then your forks do not line up with each other.
You can not use the forks to (floating) to press down, like a brush pile.
Floating forks are easier to side under a pallet for less experienced user.
I am not familiar with your loader model. What is it's capacity?
I would get at least 42" long that will work with std pallets. 48" long might be easier to see the ends of the forks from the seat.
1 1/2" thick x 4" wide forks capacity is 5500lbs at 24" and weigh about 100lbs each. 48" will be about 10lbs more each.
   / Question, pallet fork users, which one should I get #10
I vote for the rail type pallet forks that latch in place. You can dump something of off them if you want to. I have a set of lofflin forks for a Skid steer. They are 4500lb capacity. I would check around and see what all of the local dealers have. The mahindra dealer here now has so knock Bobcat forks. They look nice.
Here are mine
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
2017 Vermeer BC1800XL Towable Brush Chipper (A55851)
2017 Vermeer...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
Towable Orchard Sprayer (A55851)
Towable Orchard...
