Question on trans oil - need answer quick!
/ Question on trans oil - need answer quick! #1
Raindem
Arizona
I changed the trans oil in my JD 2305. The stuff that came out of it was red, like an AT fluid. I bought JD Hy-Gard TY6354, which says it exceeds the specifications of the factory JC20 oil (which I assume is the red stuff). But the oil I bought looks like regular oil. It's not AT fluid colored.
My question is does that make a difference? Did I put the right oil in? My local JD store is not open today so I'm trying to get an answer before I start work.
Thanks
/ Question on trans oil - need answer quick! #2
found same thing on my 2320 use the jd oil also the engine oil filters were different diameters and had to buy different wrenches for it
greg
/ Question on trans oil - need answer quick! #3
/ Question on trans oil - need answer quick! #4
Isn't the "red" merely a dye? Can't you also just buy the dye at Deere, which makes it easier to read on the dipsticks/sight glasses?
/ Question on trans oil - need answer quick! #5
AT fluid does work and had been used for years in hydostatic transmissions, but a combination transmission/hyraulic fluid is better. It has added lubrication properties in it that help reduce wear in hydrostatic system and work to keep seals in cylinders and valves form drying out.
OK, I feel better now. I just grabbed that oil off the shelf and never bothered to ask the parts guy if it was the right stuff for the 2305. The JD supplier I go to mainly deals in heavier equipment.
Thanks for the quick responses. Now to go get some seat time!
/ Question on trans oil - need answer quick! #7
Same with me..... My 790 had hyd fluid in it that had some red dye in it. The new HyGard I put back in looked like most any other hyd fluid. I think they dye it red so it's easy to tell (if you have a leak on a new tractor) if it's engine oil or hyd fluid.
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2013 BMW X28I AWD SUV (A61574)
2013 BMW X28I AWD...
Lot of 4 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
