Question on remote hydraulics
/ Question on remote hydraulics #1
jackson1
I have a JD4410 that I'm having a top and tilt put on, this will give me two handles to operate these. I am also hooking up a landpride power rake model #pr2572, this has hydraulics for angle and also hydraulics for scarifiers. I'm planning on using the same controls to use the top and tilt and the power rake, but not at the same time. What I was wondering is, if I take the hydraulics off of the top and tilt to use on the power rake will the hydraulic cylinders bleed down? I also have a backhoe with hydraulics but the handle is on the backhoe so when it is removed I have the 4 hydraulic lines that won't be used. Is there a way that I could put a handle on these to
work the power rake? Thanks for any help, what a great forum. Jackson
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL8DL188002 (A61165)
INOP/NON-RUNNING...
2002 Kubota BX1800 Utility Tractor (A63116)
2002 Kubota BX1800...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
25' SINGLE AXLE VEGETABLE TRAILER 5TH WHEEL (A62130)
25' SINGLE AXLE...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
Like New! Low Hours! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Low...
