Backhoe Question on [re]attaching a backhoe...
   / Question on [re]attaching a backhoe... #1
MadJack
Litchfield, Maine
86 Ford 2110 4x4
I just bought a Case 430 with a backhoe on it. Problem is (or was) it was put on by a real genius using 3/4" threaded rod, then had plates welded (if I dare call them welds) to the frame.
Threaded rods snapped in the middle and the >welds< came apart so the only thing holding the how on was the two 1" bolts at the bottom.
Glad I'm sensitive to "something feels/sounds different"!
I need to know what they call the part that is supposed to go where the 36" threaded rods were. they went from the top of the hoe frame (just under and to the right/left of the seat, down to a gusset on the lower frame, both having a 3/4"hole.
Anyone follow me on this? Please help.
Jack
   / Question on [re]attaching a backhoe... #2
A picture or two would be worth a thousand words.:)
Is this a 3pt mounted BH or are you describing an ersatz subframe?
   / Question on [re]attaching a backhoe... #3
MadJack
Some old fords had a big turnbucle inside fenders to clamp hoe to the studs that it went on.
tommu56
The (silver) 3/4" threaded rod starts here...
And goes down under here...
Would just like to know what the original part was called.(stupid curiosity)
I had a metal-fab friend over yesterday who says the hoe is nothing more than scrap metal so it's coming off this week and being replaced with the 3-pt hitch for now.
Thanks guys,
Jack
   / Question on [re]attaching a backhoe... #5
Thanks for the photos. Unfortunately I have no clue but maybe someone else will recognize what that is.
Maybe someone will know what they are.....
Thanks anyway.
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
2021 BOBCAT S740 SKID STEER (A52707)
2021 BOBCAT S740...
UNUSED FUTURE TP25 25" HYD TREE PULLER (A57193)
UNUSED FUTURE TP25...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A55851)
Dvorak Model 3072A...
