Question on MX5 Blade Removal
   / Question on MX5 Blade Removal #1
scodemike
Monument, CO.
LS XR3135HC
What size socket do you require to remove the blades on a MX5? I have a 1 5/16"and it is too small.
   / Question on MX5 Blade Removal #2
It is a 1 inch bolt. So, it should have a 1.5 inch head if it is a standard nut (which it looks like it is).
Thanks for the information. I had to order the socket, no one carries that size in stock.
   / Question on MX5 Blade Removal #4
You might want to pick up a torque multiplier also... The nut has to be torqued to 627 ft/lb.
I need to get one myself. I bought a MX6 a couple months back, but haven't had to do any maintenance yet. Let us know how the procedure goes.
   / Question on MX5 Blade Removal #5
arlen4720
You're correct on the size. Here's the spec's on the nut.
Part Number: W50958
Part Price: 5.41 USD
Description: Lock Nut
Specification
Weight 0.26 LBS 0.12 Kg
Thread Size 1.000 IN
Thread / TPI Pitch 14
Thickness 0.887 IN
Across Flats 1.500 IN
   / Question on MX5 Blade Removal #6
I gave up on trying to hold and torque to 600 plus pounds. I use a heavy duty three quarters inch drive air impact wrench, a metric socket and hammer away.
I gave up and went to the dealer, they only charge $30 to do the blades. The place that I ordered the socket cancelled my order, out of stock. I couldn't find a place to rent a torque multiplier and I didn't want to pay the big price for a 3/4 inch drive on line.
While at the dealer they are going to check the slip clutch, it has been sitting for a long time without use, according the guy I bought the MX5 from.
   / Question on MX5 Blade Removal #8
Last time my wife had a set changed out we let the dealer right up the road do it. Charged $30 or $40 labor I think, it was worth on the Bush Hog SQ720.
   / Question on MX5 Blade Removal #9
Hey,
Newbie question here. I have a JD 3520 and an MX5 mower. I understand the wisdom of taking the mower in for service but my dealer is far enough away and, well, ok, I admit, while I DO own a torque multiplier and large sockets, I don't own a decent flatbed trailer .... So, I would like to do the blades myself this weekend. What I don't know is the best method for lifting the mower for service. Anyone have a preferred technique? Max height on the 3ph (with blocks of course) is still pretty low, I would love to stand that sucker up and work on it at waist level ....
   / Question on MX5 Blade Removal #10
Hey,
Warning this could be dangerous. Do you have a loader on your tractor? If so use the loader to raise the rear of the rotary cutter to the height you want it. Be sure and use bracing or a prop to keep the loader from leaking down. Also limit the amount of time spent underneath the rotary cutter.
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
