question on lights for 3520
   / question on lights for 3520 #1
rick g
I just purchased a JD 3520. It's a great machine but I have a question on the lights. I never get the "running" lights on the ROPS to go on steady. They do flash but never go on steady. Are they supposed to? I am ordering the rear work light and am wondering how this is going to work if I never have a constant 12v on the ROPS. Thanks for any help.
   / question on lights for 3520 #2
Those are "hazzard" lights, not runnings lights, that's why they only flash. The work lights use a wire that is under the seat for power.
Enjoy your new machine!:D
Thanks, that clears it up.
Wired in a rear work light yesterday by picking up the steady hot lead for the running lights that are attached to the hazard warning lights. Now I can see when I put it away at night.
   / question on lights for 3520 #5
Out of curiosity, what wattage are those work lights? If you tapped into the low wattage running light wiring you may want to stock up on fuses (and a fire extinguisher, just in case!). If you found a thicker hot wire not connected to the running lights (a previous poster indicated it may be under the seat) you should be fine.
   / question on lights for 3520 #6
I'm going to be rigging my 3320 for lights soon -- looking at the wiring harnesses under the seat, can anybody who's wired lights to a 3XXX recently remember the color coding for what they used? There two sets right behind the seat -- a black wire and a purple/blue wire bundled together and a black wire and a purple wire bundled together that are just stubs. What are these for? There's a JD harness specifically for a rear work light kit that I think plugs into something already there, but where?
   / question on lights for 3520 #7
I have a JD 3320 with a FEL, and the front headlights are all but worthless. Next time (first time) the tractor goes back to the dealer it is getting additional lights installed - preferably on the underside of the top ROPS bar!!!
   / question on lights for 3520 #8
black/purple is the wire you need.. on my 3320 I have the forward light kit (2 lights) and 1 rear light kit (single light) Dealer said could't run two rear lights due to switch not being able to handle load.
hope this helps.
   / question on lights for 3520 #9
When I asked my dealer to add a rear work light he asked if I want 1 or 2. I had 2 installed and they work great. I don't know if they used the wiring harness that was on the tractor already or if they had to use another because of the 2 lights.
   / question on lights for 3520 #10
Photos please; I'd love to add some lights to my 3320.
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
JOHN DEERE LOT NUMBER 122 (A53084)
JOHN DEERE LOT...
2014 Jeep Compass SUV (A51694)
2014 Jeep Compass...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
