Question on casing
/ Question on casing #1
SABULA FARMER
Pennsylvania
Bobcat CT335SST
This is going to difficult to explain, but today while plowing some snow from my driveway, I noticed some red stains in the snow where I was parked at. I thought that maybe it was hydraulic fluid and searched every fitting on the tractor.
When I looked under the tractor (2615 gear), I found no signs of liquid loss. I did discover something that has me concerned. On the left side of the case that houses the tranmission fluid, I found a small hole just above one of the bolts. It was oval in shape. I know that there are other holes in the casings for different things, but this one is not normal. I wanted to take a photo of it, but I could not get a good angle on it. Nothing is leaking at the present time, however there is no reason for a hole to be in this location....:confused:
Has anyone ever heard of this before?
Sabula Farmer
/ Question on casing #2
Your trans fluid should not be red anyway.
The only fluid that is red would be fuel and thats only if you are buying non taxable fuel.
I agree with you. The only thing that I can think of is the red grease that the dealer greased the FEL with. I think that when the hydraulic cylinders get warm, the snow and grease mix together and then drip.
I am more concerned with the hole that I discovered.
S.F.
Since no one knows about this...are there any tractor dealers that may know what this may be?
S.F.
Here is a picture of what I have going...if this works?
It is the small hole on top.
/ Question on casing #6
I wish I could help but I just sold my last 2 2615's on our lot Tuesday.
Does that look normal to you? I think it may be a bad casting. I hate to complain, but I think that since its on the transmission case, it could turn into a problem down the road.
S.F.
More pics.
/ Question on casing #9
Have you tried emailing any of those pictures to your dealer?
It's hard for me to tell without a clear picture, and trust me I realize that's not an easy task. Maybe someone else with a 2615 can chime in.
I told my dealer about it, and explained it to him. He is supposed to take a look at it sometime soon I hope.
/ Question on casing #11
Sorry it took me so long to go look but the tractor on my lot has the same hole. I don't know the purpose of it but it is there.
Really?...the small hole above the threaded hole?
If that is the case, could this be like a breather hole?
S.F.
/ Question on casing #13
SABULA FARMER said:
More pics.
From looking at these photos and the one you sent before, my best guess is a tooling hole. It would be only used in making the parts and would be blocked off by a gasket or some other means now. Looks like a rusty color around the hole. That reminds me of a weep hole found on water pumps. I would not worry about it. That is, as long as you don't find something leaking from it.
hugs, Brandi
/ Question on casing #14
In this photo it looks like it could be a pilot (tooling) hole for the bolt behind it, before the hole was enlarged to depth and tapped. It is just too hard to tell from the photo.
hugs, Brandi
/ Question on casing #15
Yes SF I know which hole you mean and mine is a little rusty just like that one. I don't think it is anything to worry about. Relax and enjoy your tractor, it has a reputation for many many hours of trouble free operation.(I mean fun)
You guys are awesome!, Thanks for the help. And yes MANY, MANY HOURS OF FUN!
/ Question on casing #17
Not true....on my 6500 anyway. The power steering fluid is red, (ATF). I know, because I have a leak that has been there since shortly after purchasing. I did not worry about it, as it was very minor. I am now sorry that I let it go, because it has gotten worst and the fittings now have to be replaced.
/ Question on casing #18
There is also red dyed hyd/trans fluid. but it is not recommended to use in Mahindras per the MUSA techs.
/ Question on casing #19
Funny you should mention the Power Steering. The ONLY warranty item I had in the first 3 years on my 6000 was the power steering resevoir had a leak. I believe it was the O-ring at the top of the unit, but they replaced the whole resevoir. No leak since. Check on top of your resevoir, you will find an Oring about 1" to 1 1/2" in dia. this may be your culprit....good luck!. BobG in VA
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
Ag Leader PF Advantage Monitor (A65640)
Ag Leader PF...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
