Question on casing
   / Question on casing #11
Sorry it took me so long to go look but the tractor on my lot has the same hole. I don't know the purpose of it but it is there.
Really?...the small hole above the threaded hole?
If that is the case, could this be like a breather hole?
S.F.
   / Question on casing #13
SABULA FARMER said:
More pics.
From looking at these photos and the one you sent before, my best guess is a tooling hole. It would be only used in making the parts and would be blocked off by a gasket or some other means now. Looks like a rusty color around the hole. That reminds me of a weep hole found on water pumps. I would not worry about it. That is, as long as you don't find something leaking from it.
hugs, Brandi
   / Question on casing #14
SABULA FARMER said:
Here is a picture of what I have going...if this works?
It is the small hole on top.
In this photo it looks like it could be a pilot (tooling) hole for the bolt behind it, before the hole was enlarged to depth and tapped. It is just too hard to tell from the photo.
hugs, Brandi
   / Question on casing #15
Yes SF I know which hole you mean and mine is a little rusty just like that one. I don't think it is anything to worry about. Relax and enjoy your tractor, it has a reputation for many many hours of trouble free operation.(I mean fun)
You guys are awesome!, Thanks for the help. And yes MANY, MANY HOURS OF FUN!
   / Question on casing #17
wallace said:
Your trans fluid should not be red anyway.
The only fluid that is red would be fuel and thats only if you are buying non taxable fuel.
Not true....on my 6500 anyway. The power steering fluid is red, (ATF). I know, because I have a leak that has been there since shortly after purchasing. I did not worry about it, as it was very minor. I am now sorry that I let it go, because it has gotten worst and the fittings now have to be replaced.
   / Question on casing #18
There is also red dyed hyd/trans fluid. but it is not recommended to use in Mahindras per the MUSA techs.
   / Question on casing #19
Funny you should mention the Power Steering. The ONLY warranty item I had in the first 3 years on my 6000 was the power steering resevoir had a leak. I believe it was the O-ring at the top of the unit, but they replaced the whole resevoir. No leak since. Check on top of your resevoir, you will find an Oring about 1" to 1 1/2" in dia. this may be your culprit....good luck!. BobG in VA
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
2015 DODGE RAM...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
MESSAGE BOARD W/ LETTERS (A51244)
MESSAGE BOARD W/...
