Question on BX series loaders
   / Question on BX series loaders #21
Jim,
Just a few thoughts:
See my reply to your post re. types of tires; I doubt you need turf tires.
Though I prefer the BX, did you know Cub Cadet makes a tractor that is in the same class as the BX and the Massey Ferguson? It has both fel and bh. With NH and JD you have to go about a ton heavier & mucho $ more before you can get a bh. Anyhow, since you're doing such meticulous comparison & contrast, you might want to examine the specs on the CC. (It's all on their web site.)
The fel on a BX won't dig without a tooth bar. I'd recommend bolting it on because there may be occasions when you need to gently scoop soft material off of a smooth and costly pavement and not worry about scratching it. Bolts make on/off easy whereas if it's welded on you'll have to risk scratching or ripping someone's driveway.
Good luck,
Tom
Thanks for the info Tom. I did a quick look at the Cub Cadets but could not find any info on a tractor from them that would take an FEL and a backhoe. Do you know what model it is? I was planning to have a the toothbar be a bolt on - I might use this to clear my driveway in the winter and figured the teeth wouldn't be good to have on when doing that.
   / Question on BX series loaders #23
Jim - try Townline Equipmwnt in Plainfield NH or Emerich Sales in Charlton NY. I might also try Pinnacleview. I believe Emerich will be cheapest including delivery to you.
   / Question on BX series loaders #24
Tom,
I have to disagree with you on the BX loader. It will dig without the toothbar. In regular soils and such it actually digs quite well....better than I expected. I can only imagine how much better the tooth bar will be though.
   / Question on BX series loaders #25
</font><font color="blue" class="small">( ( ...Cub Cadets...could not find...tractor...that would take...a backhoe...what model it is?)</font>
All of their utility tractors take backhoes. In the 5000 series, I would not consider the gasoline twin cylinders, but the 5234D has a 3 cyl. diesel 23hp. It weighs less than the BX or the Massey Ferguson. It also has more hp at the PTO. Go to this link:
CC 5234D
If you click on the accessories link, it doesn't list a bh, BUT, if you go to the specifications link, it DOES indicate an optional backhoe. The overview page for the 5000 series tractors used to show a photo way down at the bottom of the page of a 5234D with a bh on it. For some reason, it's not there any more. I'm now wondering if they have withdrawn the bh, have erased the photo and taken the bh off the assessories page, but forgot that they had it listed on the specifications page /forums/images/graemlins/tongue.gif /forums/images/graemlins/confused.gif
Anyway, you might want to contact a dealer if you're really interested in pursuing every detail. The fact that their info. is a bit unclear along with their affiliation with MTD, having fewer dealers, and not having the good reputation of "Bota made me drop them from consideration.
Good luck,
Tom
   / Question on BX series loaders #26
</font><font color="blue" class="small">( NO, I didn't break it up with the backhoe. I rented a Bosch electric jackhammer and it was not very effective. It took about an hour and lots of body punishing to break up one section of concrete....NOT FOR ME!! I rented a Bobcat 763 with a hydraulic breaker on the front...This is clearly the right tool for the job. It took about 45 minutes to break up the rest of the walk!!! It cost about $120 to rent the Bobcat and breaker but it was money well spent. Then I moved all of the concrete with the BX. The BX is like a little tank it will move an impressive amount of material. )</font>
I would think the BX23 backhoe would be able to break that up with no problem correct ? It seemed like the perfect job for it
Duc
   / Question on BX series loaders #27
</font><font color="blue" class="small">( ...BX loader...will dig without...toothbar...In regular soils...)</font>
I have to admit, I don't have "regular" soil. I have hard clay. I have to rototill it into powder, but even then I can only grade along the ground so that it scoops into the bucket. Even when I'm scooping from a sandpile, I need inertia of forward momentum to fill the bucket. Can you actually have the tractor at a standstill and use the breakout force from the hydraulics to actually "dig" down into the ground the way a backhoe does? I have difficulty visualizing an LA211 doing that in anything except a sand dune or some other soil that's already been highly loosened. I can't imagine an LA211 at a standstill actually "digging" in packed loam using only breakout force and having no toothbar.
   / Question on BX series loaders #28
</font><font color="blue" class="small">( ....... I have difficulty visualizing an LA211 doing that in anything except a sand dune or some other soil that's already been highly loosened. I can't imagine an LA211 at a standstill actually "digging" in packed loam using only breakout force and having no tooth-bar.
)</font>
I have a tooth-bar for my BX22 LA210 (virtually identical to the LA211 that is used on the BX1800/2200) loader and it is presently located in the garage on the floor. Haven't put it on the tractor yet this season, because there is nothing that I have found that I need it for. I have standing piles of loam that I purchase a few years ago. I buy them from a local farm that mixes manure into the piles, so I let them ferment for a while before use. My loader has no trouble digging in these piles that have been in place for 2 or 3 years. I can tell you that if I try to dig a pile with a shovel, that I will tire long before I get a wheel barrow full. The Kubota has no problem digging at all. In the morning I will post a picture of one of the piles that I dug in last week. The walls of the pile are still vertical from where I took out material with the bucket indicating that density of the pile. Don't underestimate the power of these little dynamo's of a tractor.. /forums/images/graemlins/wink.gif
I was mostly interested in the toothbar because I need to dig out sod - I had rented a Terramite before and tried digging this out and could not get anywhere with it. The bucket on that machine did not have a toothbar. I figure if the toothbar helps even a little bit then I will be happy. All the response I have gotten has been very helpful - Thanks
   / Question on BX series loaders #30
If you want to dig out sod and reuse it, the tooth-bar will destroy it. If you don't care, then the tooth-bar will be great and make the job quick. Part of the trick of digging with the bucket is technique. This is something that you learn, but can't be explained or taught by reading a post. I have filled bar tires and they make digging a lot easier also. I have also filed a sharp edge on my bucket by doing snow removal with it this winter. It digs better this spring than when it was new. I believe that it is the sharp edge on the bucket that has made that difference for me. It also might be a senior moment not being able to remember last fall by comparison. Either way, you will love your new tractor and will rapidly learn to use it to its full potential. I had to go out to the garage for another picture, so I snapped one of the tooth-bar. If it wasn't so large, it might have gotten lost on the floor.... /forums/images/graemlins/frown.gif Cleaning that garage floor is on the list for the next rainy day. /forums/images/graemlins/crazy.gif
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2007 Peterbilt 379 T/A Day Cab Truck Tractor (A60460)
2007 Peterbilt 379...
light tower (A56857)
Electric Golf Cart (A56859)
Electric Golf Cart...
2016 Doyle 10T Tender (A56436)
2016 Doyle 10T...
