Question for 1845 owners
/ Question for 1845 owners #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
Occasionally, when I stop and try to move forward/backward slowly, nothing happens when I slightly push the treadle. If I push the treadle a little more, then the tractor will lunge forward/backward. The behavior is similar to when you first start the tractor and need to energize the break circuit to get moving. But this happens even though the break circuit is already energized.
However, there is a way to stop the behavior too. Consider the following scenario: I'm moving forward and then stop and try to go slowly backward. If the tractor does not move when I slightly push the left pedal, I will then push the right pedal to move forward a foot or two. Then when I try to go backward, the tractor moves smoothly. I think this may have something to do with a worn shuttle valve. Any ideas?
Hmm...where is this valve located?
/ Question for 1845 owners #5
If you look at the bottom of the page link in the previous post, it shows two photos of the valve from front/rear, which should help you find it. On mine it is behind the hydraulic tank on the left side of the tub, under the diesel tank, basically below and forward of the draft control valve. But that's for a 1445.
All the best,
Peter
2015 Audi A4 Sedan (A61574)
2015 Audi A4 Sedan...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
2007 Regal 30 Express Cruiser Boat with T/A Trailer (A61574)
2007 Regal 30...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2019 FREIGHTLINER CASCADIA CA113DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
John Deere 302A 50HP Front Loader Utility Tractor (A61572)
John Deere 302A...
