Tires Question about tires keep going flat.
/ Question about tires keep going flat.
Jon Chanoski said:
You stated in one of your posts that you had to feplace tires all around 4 times this year. A tractor has 4 tires so if you replaced tires all around 4 times this year that is 16 tires. Or did you mean you repaired them all 4 times?
Yes that's what I meant to say repaired them all. Sorry about that.
/ Question about tires keep going flat. #52
I'm in the "business" tire wise and the only solution to your problem is to have them foam filled.If it were me though,I'd buy new R4's to have filled and keep the old one's as spares if I could find extra rims.The deeper tread overal on the R4's plus the fact they don't have such huge voids (which have way less rubber than the lugs) that would allow them to be cut or punctured as easily.
The reason for buying new is so that they won't have possible separations in them that could cause a failure.The foam only replaces the air and the tire is
still susceptible to coming apart,and they won't last forever.So if you're going to spend the big bucks,make sure you spend it wisely.
It will add to the weight about as much as they would if filled with calcium chloride or rim guard.
I have a cure for Hoosier Man's hay field problem too of course,invite someone to hunt off all those horny bucks and the sheds will disapear.:thumbsup: and delicious to eat for sure too mmm :licking:
Al
/ Question about tires keep going flat. #53
Wow, $1000, I'm not sure if I would spend that much. I think I would just buy myself a good tire plug kit and just keep plugging the tires as I hit the nails. Meanwhile I would keep looking for a place that could foam the tires for less.
/ Question about tires keep going flat. #55
I think I paid $330 for both rears on my BX-23
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61307)
2023 Kubota...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2005 International 4300 S/A Dump Truck with Scissor Lift (A59230)
2005 International...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
