Tires Question about tires keep going flat.
/ Question about tires keep going flat. #31
My2009 BX2660 had one front tire that had a slow leak. I removed the tire and sealed the steel rim and tire bead with bead sealer and have never had another problem. As to tire sealant, I've had good luck on other small equipment with "Linseal" which is a green slime with black specs. As has already been mentioned, maybe you are not using enough. Otherwise, it looks like you are heading for the full foam job. Over the years, I've cleaned my place up from thorny locust, russian olive and osage orange hedge; but still have to police up some fallen stuff now and then.:(
/ Question about tires keep going flat. #32
Had my rear BX tires Foamed and never looked back... also more stable.
Does foaming equal harder rides and more stress on axle components?
/ Question about tires keep going flat. #34
green slime has worked well for me on tractor and atv
Given the choice I'd rather not use the green slime. It seems to be quit corrosive to the rims. Is fixing the roofs an option seeing as that's where the nails are coming from?
Abe
Abe
Not really cause the tires have so much slime in them to fix earlier holes.
/ Question about tires keep going flat. #36
It's pretty bad I have to wear steel toe and plate boots in my yard
If it is *that* bad a magnet is your only hope. They sell huge magnets at roofing supply houses.
I tore down a 20x20 shed on my property (mostly by hand). We tried picking everything up but I got 3 flats in 15 minutes afterwards. Bought a relatively small roofers magnet and quickly filled a 5 gallon bucket with stray nails.
And if you can't afford a magnet, you definitely can't afford foamed tires. :(
/ Question about tires keep going flat. #37
I went with medium density... they offered a low density and high density... although the high density is for heavy equipment.
I rarely road my BX... most of my land is steep and 99% I'm in low range... so ride of speed has not been an issue.
The Dealer did not recommend Foam if I primarily do finish mowing... said the extra weight and higher speeds are not ideal...
I have not foamed the front because my Kubota Dealer advised against it... I do run Slime and so far so good.
I will look into the magnet idea and see what happens.
/ Question about tires keep going flat. #39
From the magnet web site referred to:
call 1-800-221-0516 and I'm guessing you can order w. check or M.O.
/ Question about tires keep going flat. #40
I have seen a thick rubber liner shield that can be placed inside the tire between the tire and tube. I don't know if they even make these anymore.
Although I've never used them (tire liner), I see that GEMPLER'S - Muck Boots, Carhartt Workwear, Battery Chargers & more - Official Site has the "tire guard" liner advertised in their catalog. Apparently you have to use an inner tube to hold it in place. But it is advertised as..."virtually never wear out and are a fraction of the cost of foam-filled tire."
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
