question about suburban windows
/ question about suburban windows #1
tractorwheel
both the back windows on suburban will not roll down. when the window controls are used from the drivers seat i can hear a clicking noise coming from each back side window but the window does not do anything. it is a 2001 chevy suburban and i have checked the fuses. does anyone have any suggestions before i take it to body shop? thanks.
/ question about suburban windows #2
Yep...either the cable for the regulator broke or it's disconnected. Common problem due to design. Take the door panel off and take a look, it's not hard to repair or replace the regulator. Seems odd that both failed at the same time.
Good luck...
/ question about suburban windows #3
I assume the windows don't work from the back door switchs either, try slaming the door real hard.Sometimes the brushes wear down and don't make contact.
/ question about suburban windows #4
Slaming the door might work to wake the motor, but why beat on the latch and door jamb? Just give a couple smacks with the palm of your hand to the inside door panel just below the arm rest.
/ question about suburban windows #5
What you're likely hearing is the drive gear on the motor trying to turn the broken "ladder-like" plastic drive that actually moves the windows, unless this has an older style lever & gear drive mechanism, then the drive gear is likely stripped.
/ question about suburban windows #6
Yep, sounds like it's time for new window regulator assemblies.
/ question about suburban windows #7
Probably going to be pretty pricey. Check local junkyard for cheaper replacements, but then you don't know how long they will last. I bet new are in the $300.00 range.
/ question about suburban windows #8
On my truck, both passenger side windows stopped working within a week or so of each other. Since I always drive, I haven't worried about fixing them.
/ question about suburban windows #9
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
PALLET FORK ATTACHMENT FOR MINI SKID STEER (A61572)
PALLET FORK...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
