Question about pond ice thickness
/ Question about pond ice thickness #21
Beautiful pictures! /forums/images/graemlins/smile.gif
Looks like lots of fun.
/ Question about pond ice thickness #22
<font color="blue">Larry, Be careful as the ice will not be the same thickness on the whole pond. It will be thinner on the edges, and snow cover insulates and will not allow the ice to get as thick. </font>
In general, I agree with you, with exceptions. The lakes we fish on are usually open water or very thin ice in the center and very thick on the edges. It also can depend on wind, shelter, water depth, color of the bottom(black bottoms in shallow water warm quicker than light bottoms) and the local goose population. Geese like to keep water open and large flocks can keep the center of a large pond open long after the edges have frozen solid. The centers of these lakes also open up sooner. And don't forget about springs. Stay away from high banks, too. The water pressure in the ground in a high bank tends to push ground water up under the ice. Ground water is alway warmer and weakens the ice. Around here the ground water is in the mid 50s year round.
And like you said, snow cover is a huge factor. Best to test the thickness often. It is nothing for me to drill 20 holes before I even start fishing when testing ice. I get more confident as I frequent a lake through the season. However, if the weather changes, we get a warm spell or snow, I check it all over again as I go.
If I owned a pond and wanted to skate on it, I'd invest in a decent ice auger. They can be had for under $40.00. I can drill through about 10" of solid ice in about 8 to 10 seconds with my Mora. Cheap insurance. /forums/images/graemlins/smile.gif
/ Question about pond ice thickness #23
I remember something about an "ice chart" the army uses to determine what equipment weight they can drive over frozen rivers, lakes etc.
/ Question about pond ice thickness #24
Don't EVEN go there. Weight and ice thickness figures could not come close to providing even a partial answer.
Suppose the tractor weighs W and the ice is E inches thick, and unknown factor = T where T is any one or more of the following:
1. High winds
2. Sudden increase or decrease in underlying water temp.
3. Center of gravity or load changes (as in a loader being filled or emptied of snow)
4. Change in surface temperature (like adding the sun and the ambient temperature of a 30hp diesel engine 11 inches above the ice for instance) for an unknown period of time.
WxExT = "Holy S**T!
I don't care if W = 500 lbs and E is 12, if you're out on the ice, T is gonna bite you and take u under sometime.
A real head scratcher. /forums/images/graemlins/laugh.gif
/ Question about pond ice thickness #25
<font color="blue"> WxExT = "Holy S**T! </font>
Nice formula. /forums/images/graemlins/tongue.gif
I'd debate point 4 since heat rises, but you've still made a good case to not do it... at least with my tractor.... let's use someone else's tractor and run some tests. /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/wink.gif
White Metal Roof Vents (A64194)
White Metal Roof...
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
East Texas Gooseneck Trailer (A65563)
East Texas...
2013 Kobelco SK26LC (A64126)
2013 Kobelco...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
John Deere 7000 2R Planter (A66285)
John Deere 7000 2R...
