Question about log splitter on M6800
/ Question about log splitter on M6800 #21
It's really cool when somebody comes to TBN with a question and pretty soon has mastered the subject. Good going!
/ Question about log splitter on M6800 #22
to be absolutely honest i think you are barking up the wrong tree with the relief valve. when a relief valve poops off, the system pressure will stay at the relief setting until the load is reliesed, (moving the control lever on splitter other direction should do it). then it reseats. it will not stay unseated until all oil flow stops as you describe(having to relies the remote lever then re engaging). it will be interesting to 'T' the guage in to the system before the splitter control valve, because when this prob happens, if you have pressure there it's either in the splitters valve or oil cant return to the tractor. just to go back though. i still think its the couplers, either the one's on the hoses or the female one's on the tractor. do you have another hydraulic impliment you can swap the couples out on and fit to the splitter. i may be wrong on this (definantly isn't the first time) but that would certainly be my guess if i was trying to diagnose it. bye the way, these couplers are cheap, about $15 each (AUS). is cheap peace of mind really, you said you needed to replace the hoses, maybe do it at the same time.
/ Question about log splitter on M6800 #23
as for which relief poops first, to be honest i dont care, because pressure in a fluid is transmitted without lose through the fruid, so as long as one relief is working, the whole circiut is protected. yes it is fine to plumb the pressure guage in as you describe, i have a hydraulic flow tester which i plumb in exactly the same way for exactly the same reasons, only diff is i can tell what the oil flow is doing as well. (for you its a shame flow testers are worth a fortune, would be handy) but dont panic, you'll figure it. keep us informed.
F-450 SuperDuty Flat Bed 4WD (A63688)
F-450 SuperDuty...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
31" Minin Excavator Bucket (A66285)
31" Minin...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
Used 20' Container (A62679)
Used 20' Container...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
