Question about lift (pivot) pins
   / Question about lift (pivot) pins #1
joshlee
Platinum Member
Beaver Springs, PA
Power Trac PT1430 Year made 2016
My Steiner has pins with no grease fittings or anything to stop the pins from rolling inside the mount holes. Therefore, obviously likely to wear the holes lose. Does anyone think that a grade 8 bolt with a nylon lock nut would work without rolling when lifting a heavy load?
Thanks for reading,
Josh
-100_0164-jpg-100_0165-jpg
   / Question about lift (pivot) pins #2
I have no idea if the bolt grade will impact rolling/not rolling but.... My previous tractor had 5500 hours on it when traded in and the non-lubed FEL pin holes had not shown any signs of rounding out yet.
   / Question about lift (pivot) pins #3
My 60 year old Ferguson loader had no sign of wear on the pins. The bushings were another story.
Thats amazing. Those holes must be polished, or become polished from the movement? I'll keep that in mind oosik and also about the bushings, old pilgrim.
Thankyou
Zero Turn Mower (A48082)
Zero Turn Mower...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2006 ISUZU NPR (A50323)
2006 ISUZU NPR...
