Question about grinding rebar
/ Question about grinding rebar #1
AmericanTractorDriver
USA
None
Hello,
Sorry if this is slightly off-topic, but I think it's the closest area?
Today I found someone selling some scrap (straight, but has become rusty) 3/8" rebar for about $0.15/ft. I cut the 10' lengths into (3) 40" lengths to use as posts to support chicken wire around some raised beds. Cutting went well with the angle grinder... about 15 seconds a cut. next time I'll use a very thin wheel which hopefully will speed up the cut.
As to grinding points on the stakes... I just did a basic 45* cone, and even that took a long time. I am using a standard 4.5" grinding wheel. Is there any faster method (for a small run) or a better wheel to use? Compared to sharpening lawn mower blades, etc., it seems like this rebar is taking forever to grind.
I'm going to try to hit them with the wire brush quickly, and then paint. Just don't want to end up spending 5 minutes on every stake!
Thanks!
/ Question about grinding rebar #2
I have made stake-like things out of rebar before. This may be too obvious to even mention, but instead of grinding a point, I just cut them off at 45-degree angles, to make a point, no further grinding required.
EDIT: And I second your opinion that a thinner wheel is better. People have also told me they got very good results using a fine-toothed metal blade in a reciprocating saw, but I've never tried that myself.
/ Question about grinding rebar #3
Instead of cutting at 90 degrees put a 45 on it
Looks like this | /. /. |
Two stakes
As to the angle - it may depend on the soil conditions - but do the posts not want to drive in at an angle as the point drives through the dirt? Or - if that does happen - maybe making two cuts (a "V" nose) would eliminate any potential problems. Thanks for the idea, now I'm glad I asked!
Thanks
/ Question about grinding rebar #7
I would agree you usually don't need a point on 3/8 rebar, but if you do, just make the 45 degree cut with a cut off wheel.
James K0UA
/ Question about grinding rebar #8
I use 3/8 rebar to tie tomatoes..After a couple years---what points?? they drive fine with 2 lb ball head hammer?.
/ Question about grinding rebar #9
I also use three 3/8" sticks of rebar per tomato cage for extra support. No points necessary. The only time I have put points on 3/8"x12" rebar was to spike them through pre drilled fence end posts and into the horizontal "H" brace post.
What do you mean 'what points?'
I am not a big fan of tomato cages but have contemplated using a single pole of 1/2" rebar about 6' tall at each plant for some structure to tie the tomatoes to.
/ Question about grinding rebar #12
Things about rebar.
The grade designation is equal to the minimum yield strength of the bar in ksi (1000 psi) for example grade 60 rebar has a minimum yield strength of 60 ksi. Rebar is typically manufactured in grades 40, 60, and 75.
Common rebar is made of unfinished tempered steel.
Fastest way to cut rebar is with a metal cutting carbide blade in a chop saw.
/ Question about grinding rebar #13
i usually don't point mine.. but if I do.. it's just a single angle cut. if I'm feeling real 'retentive.. a double angle cut..
/ Question about grinding rebar #14
yeah, Mine had a point, but after being in the ground and then in the weather, the points went away. they are kinda blunt on the end..from driving into clay and then rusting...If i still used them for tent pegs, then it would be two angle cuts??
/ Question about grinding rebar #15
Instead of buying a different wheel, Buy a bigger hammer or eliminate both with a Plasma Cutter.
Informational Lot - Financing (A63689)
Informational Lot...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
2005 Katolight VSD60FGJ4 60kW Standby Diesel Generator (A61572)
2005 Katolight...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
2014 Jeep Grand Cherokee 4X4 SUV (A61574)
2014 Jeep Grand...
Rhino RC20 (A64119)
Rhino RC20 (A64119)
