Question about drill bit from a beginner
/ Question about drill bit from a beginner #1
mea104
Hi, defintely new to tractorbynet, and new to many things power tools. Right now, I need to use a #55 drill bit (.520) I think, and it is too small to be used by my step dads drill. I think I either need like a mini-drill for really small bits or some sort of adapter, that will help the #55 drill bit fit into my step dad's big drill. This may be a super elementary question, but you might be surprised at how much research it tookto even find out that I maybe could use and adapter, which would be great. By the way, I don't know y step dad's make and model number, I think its craftsman, but from the little I know about power drills, is that it looks very standard for typical drill bits. Any help?
/ Question about drill bit from a beginner #2
Welcome to TBN.... good question!
Well, I had to look up a drill bit chart to make sure...here's the chart I used..
Drill Bit Size Chart
size is .0520 inches... the leading zero makes a difference...this is a rather tiny bit.
if you are going to be doing much work with tiny bits and tools, suggest you simply fork over a few bucks and get a tool that is sized for this job...with appropriately sized chucks, etc... look into things like this..
Dremel is the premier standard for such tools.
4000 High Performance Rotary Tool / Model: 4000
Harbor Freight, if you have one in your area, has lower quality tool with similar function.
Harbor Freight Tools
yean i meant its .0520 thanks. And thanks for welcoming me in! Well actually I only really need this tool for one job. If I want to to shop arond, what is the name of the tool I am looking for? Through the link you provided, it looks liek the name of the tool Im looking for is a rotary tool, is that correct?
/ Question about drill bit from a beginner #4
yep, rotary tool.... has a small chuck that takes small tools, drills, grinders, saws, sanders, etc...
this is the kind of thing that numerous people have... ask a few friends, you may find someone who has one they will lend you for a one time use.
/ Question about drill bit from a beginner #5
Welcome:)
I had to use a small bit while ago and no chuck would hold it. It was actually smaller than yours - for carb venturi - but I put masking tape around the shank and used my regular chuck. The bit is flexible and if you are careful you can get away with it.
/ Question about drill bit from a beginner #6
You might even try one of those small stirring straws you get with coffee and such. Cut it off to about 1/2 " then put the bit in the straw and see if the drill chuck will clamp it tight enough. That small of a bit is going to break if you bend it much at all whilst drilling.
/ Question about drill bit from a beginner #7
If it's a 1 time thing try the straw or tape, just take your time. Otherwise A dremel tool will work and you can find cheap ones.
/ Question about drill bit from a beginner #8
If you are drilling something soft or thin, there is a mandrel type tool that is like an exacto knife, that will hold a small bit and rotate it by hand. I have even flattened and sharpened a straight pin and used it as a bit.
Another option would be to take a brass tube, like from a hobbie shop, and split it and use it as a reducer when chucked in a drill.
/ Question about drill bit from a beginner #10
Toolmonger Blog Archive Chuck Micro Drill Bits
/ Question about drill bit from a beginner #13
Try a different drill. Some will hold an even smaller no. 60 quite well. It depends on how worn the chuck is and how well it tightens up.
/ Question about drill bit from a beginner #15
G'day Willl i gotta ask what the heck do you use that on ??????????
Jon
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2022 J&M TF212 Rolling Harrow (A63116)
2022 J&M TF212...
2008 28ft. Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A61569)
2008 28ft. Regal...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
2015 Chevrolet Silverado 3500 4x4 Service/Welding Truck, VIN # 1GC2KYEG3FZ124159 (A61165)
2015 Chevrolet...
2006 Ford Escape SUV (A61569)
2006 Ford Escape...
