Question about digging with backhoes
/ Question about digging with backhoes #21
There are services that use BobCat type machines with vertical augers to take soil samples. The auger has 8 foot extensions and can literally go as deep as necessary. I do not think you will find a backhoe that goes 10 feet deep that will fit a tiny 1 foot wide bucket.
They make a 12" bucket for my Case (and pretty much any other 580) and it will dig to 18' with the Extendahoe.
What's the chance there was some communication? Are you sure it is 10' and not 10"? Or maybe it is a sample at 10' intervals in a given area?
I talked to the person the is communicating with them and he gave me some more information. They have 5-6 holes they are planing to dig and he gave them approval for a backhoe, but I am pushing for a drilling rig. In each hole the person running the project want to scrap dirt from the side of each hole at 2', 4', 7' and 10'. To me it sounds like a funeral waiting to happen, especially since we know that there is cobble at least 7' and I would guess cobble makes the ground even less stable.
A friend of mine offered to give me a little quicksilver if I want the project to end quickly!;)
/ Question about digging with backhoes #23
Okay, you are going to have to tell us what the purpose of all these holes and scrapings is. Are they trying to find pallet artifacts or something ? :D
They swear its for vineyards, but maybe they are really after gold!:laughing:
/ Question about digging with backhoes #26
I would still core this as it will give them all the info they want. IF I USED A BACKHOE I would take the samples with the bucket at the intervals mentioned. No way I would let some one in the hole, and can't possibly see the need anyway.
/ Question about digging with backhoes #27
The people that checked our soil used a Bosh hammer drill with 2 " auger bits. Each bit is three feet long; they just drilled the hole raised the bit immediately dropped into a plastic bag and cleaned the drill off into the bag. Took about 30 minutes for each hole and gave samples every three feet. Cost of Bosh drill and bits,,,,,,,, $35.00 cdn per day
/ Question about digging with backhoes #28
I also have a one foot bucket for my ten or so foot hoe. Depending on soil type, cleanout can be a major PITA!
/ Question about digging with backhoes #29
Tom,
It's for soil samples for leasing the land for a vineyard. It was stated in the first few OP's posts.
hugs, Brandi
/ Question about digging with backhoes #30
I have to throw in with the side saying "why in the world would you use a backhoe for this?" Wrong tool, get the right one.
/ Question about digging with backhoes #31
Geo techs hire me with the backhoe on a regular basis to dig test holes. I have a 12" but they prefer 24 or 30" buckets so they can see the sides of the hole. Nobody gets in the hole. They avg. 12' deep and samples are taken 1 to 2' depending on the soil types and depth of each layer.
/ Question about digging with backhoes #32
Seeing the layers of the soil makes a lot of sense. Especially if there is something down there that they are specifically looking for
/ Question about digging with backhoes #33
When I built my house I knew that I had high ground water level so we had a soils report done and they used a truck mounted drill rig to bore down a ways then dropped a hollow tube into the hole, then they dropped a weight a set distance to pound the tube into the hole. This gave the engineer a core sample of 18" and they kept track how many times they dropped the weight, which was converted to load bearing capacity of the soil at each sample depth. This was done at 3' increments I believe and 1 hole was 22'. Of course the drill went through the sand stone layer at 9' which stopped the water from going deeper, so I followed that layer when we started digging a french drain instead of doing it at 4' like was recommended in their report. No more water problem:)
/ Question about digging with backhoes #34
That was my thought.
Don't worry about me going into the hole. No chance of that. Some people are interested in leasing some of our land to grow grapes on and they wanted to get some samples, but I wasn't looking forward to a series of 10x6x10 holes on out property.
Since they are wanting to lease the land let them pay for having it core drilled.
/ Question about digging with backhoes #35
I once borrowed a 3-pt post hole auger - it was slick!
Only went down about 4', but I'm sure you could add pipe extensions.
It would take some tactical manipulation to get the depth (you'd have
to think it through a bit - like drill a few feet, take a sample with a
piece of EMT conduit sharpened at the end, drill deeper, take sample,
then deeper - lowering the drill with one more extension before attaching
to the power head each time)
But it'd probably be easier than a backhoe.
/ Question about digging with backhoes #36
Maybe they read this:
" ... Soil drainage is one of the most critical factors in site selection. Poorly drained soils
cause poor root growth, resulting in slow vine growth, poor yields and reduced vine
vigor, and ultimately a lack of longevity. Grape roots may penetrate to depths of 10
feet or more in well-drained soils, but may be restricted to two feet or less in poorly
drained soils. ... "
https://agronomy.unl.edu/c/document_library/get_file?uuid=7acb5bee-54a3-4e95-85f8-dbac7d40f7fa&groupId=4128273
/ Question about digging with backhoes #37
Wow, I never would have thought grape roots went so deep.
/ Question about digging with backhoes #38
I agree with bulldog69...core drilled is the only way I would let a potential leasee take soil samples. There's no way I would let someone dig multiple test holes with a backhoe on any land I owned. You never get all the dirt back in the hole and as what dirt is there settles you'll get left with a bunch of nasty little holes that could cause you untold grief if Murphy rears his ugly head.
/ Question about digging with backhoes #39
That was pretty much how we had it done back when my geotechnical engineer needed test holes. We could
not drill because of all the large rocks, so the contractor used a Case 850 crawler with backhoe. That was
"only" a backhoe, but it made short work of it. 10 to 12' holes.
GREAT PLAINS 2400 TURBO CHOPPER (A64278)
GREAT PLAINS 2400...
Winchester Sign (A64557)
Winchester Sign...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
John Deere 4040 Tractor (A64047)
John Deere 4040...
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
