Question about BX2350, 54" MMM?
   / Question about BX2350, 54" MMM? #1
HJT
SW Iowa
2007 BX2350
What size are the mower blade spindel bolt head, to remove blades? Book says 30.2, but have a 30mm and won't go on. Also have a 1 1/2" and its to big. A 31mm would be about right, but don't seem to make one. Will 1 3/16 work? Its about same as 30mm. I am tired of fighting trying to hold a wrench on top spindel nut and bottom blade bolt and hold a board in deck to keep blades from turning, all at same time. I need a impact socket, what the devil size will work? Thanks hjt
   / Question about BX2350, 54" MMM? #2
1 3/16 is it.
   / Question about BX2350, 54" MMM? #3
I was thinking I used 30mm for mine. Sometime they get a little gunked up with grass and you have to clean them off.
   / Question about BX2350, 54" MMM? #5
Oops- mine is a 60 in. Didn't see that. Different I guess. I use a 1 3/16.
   / Question about BX2350, 54" MMM? #6
1 3/16" is 30.2 mm (actually 30.16)
.2 mm is only .008" so most 30mm sockets will probably fit.
So for a change, looks like everyone is right including the book!
Well, that certainly is strange, because a 30mm will absolutely not fit on mine, and I bought it brand new, so should not be cobbled up by someone. Guess will pull one of them off and try to find some that do have 30mm head. hjt
   / Question about BX2350, 54" MMM? #8
Just try a different 30 mm socket. Not all sockets are manufactured to the same clearance. Or just get a 1 3/16" socket.
   / Question about BX2350, 54" MMM? #9
I use a 1"3/16 12 point socket. Just took mine off the other day to sharpen them.
I pulled one out and checked across the flat sides with set of dial calipers and it measued 1.200 one side and 1.198 on another side. Didn't measure the third side. A 1 3/16 is 1.1875. Hope it will be big enough. Will be getting one friday and see if it fits. hjt
John Deere 300 Tractor W/Loader (RUNS) (A50774)
John Deere 300...
2016 Ford F-250 (A50120)
2016 Ford F-250...
1265 (A50490)
1265 (A50490)
2018 JLG 2632ES 26ft Electric Scissor Lift (A50322)
2018 JLG 2632ES...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
