Qickrete Mixing Question - Tractor Bucket
   / Qickrete Mixing Question - Tractor Bucket #1
Old Red
Platinum Member
Western Kentucky
Kubota M6800 HDC
I borrowed a buddy's wheel barrel to mix up 8 eighty pound bags of concrete the other night. I need to mix up about 11 more bags. He took his wheel barrel. I do not own a wheel barrel and would rather not buy one for this project as my bucket on my BX23s is my everyday wheel barrel. Anyway, can I mix bags of concrete in my bucket? Is it a pain to do? Does the wheel barrel design make it easier to mix than a tractor bucket or is it all the same? I will be shoveling the concrete out of the bucket vs dumping it.
Any advice on using the BX series tractor to mix concrete? Should I just go borrow a wheel barrel?
   / Qickrete Mixing Question - Tractor Bucket #2
A bucket is a bucket whether it has a single wheel and two wood handles or four wheels and hydraulics.
   / Qickrete Mixing Question - Tractor Bucket #3
The concrete doesn't care.
Your bucket will work fine.
   / Qickrete Mixing Question - Tractor Bucket #4
I agree. I have mixed in my tractor front loader and then rinsed out the bucket and the tractor never new. Plus you can mix it in a safer place and transport it to the job site. My wife calls our BX "the powered wheelbarrow.
   / Qickrete Mixing Question - Tractor Bucket #5
A wheelbarrow might dump it better. Depends on where it's going.
If using the tractor bucket, make sure you clean it very well. I have concrete on several pieces of equipment that seems impossible to get off. Unbelievably impossible!
Thanks. I figured as much and the first time mixing I was worried about getting concrete stuck in the bucket but I went and sprayed that wheel barrel out and it cleaned up nicely. I also have that Pirhana Tooth Bar from BxPanded on the front. Probably get in the way a bit, but I'll manage. I just didn't know if how the bucket is designed if it was more of a pain, less of a pain, or the same amount of pain mixing bags of quickrete up.
Thanks, looking forward to getting my sons Goalrilla in the ground once and for all!!
   / Qickrete Mixing Question - Tractor Bucket #7
Aside from cleaning, my biggest worry with hand mixed concrete is avoiding unmixed, dry, pockets of material. I try and make it soupy, then slowly add more dry material. A wheelbarrow and a garden hoe does a good job of making sure it is well mixed. Better than a tractor bucket.
   / Qickrete Mixing Question - Tractor Bucket #8
I'd just go rent a wheelbarrow or a small mixer. The proper tools for a job are usually worth the cost.
   / Qickrete Mixing Question - Tractor Bucket #9
A hole in the ground is a proper tool for mixing Quickrete.
Yep, they actually had a mixer for rent you pull behind your truck for $55 dollars but I didn't know what the learning curve was like on that. So I figured wheel barrel or tractor. I refuse to buy a wheel barrel since I own a BX. I thought I was gonna be able to do away with the shovel since I bought the bx backhoe, but I just dug a 4 feet deep 20 inch diameter for my son's big basketball goal.
Excavator Mounting Plate (A50775)
Excavator Mounting...
Oil Tank (A50775)
Oil Tank (A50775)
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
35176 (A55758)
35176 (A55758)
