pvc vs cpvc glue
   / pvc vs cpvc glue #11
I think the purple dye is just so you can see that you primed it and where the extent of the priming went. Maybe just put in for the QC inspector so he can verify that it was primer prior to glue.
   / pvc vs cpvc glue #12
When that cement thickens in the can, I stir in some MEK, to put it to the right consistency again. MEK is the solvent used in those glues.
   / pvc vs cpvc glue #13
You think I keep MEK around when I can't even find my glue when I need it?;):laughing:
jenkinsph said:
Try the blue Rain or Shine cement for pvc sprinkler pipe next time. It will work if the pipe is still wet, good for situations where it is difficult to get the water to completely stop dripping.
Steve, what kind of glue do you use to hold the joints together when you hit the line with your backhoe bucket?:ashamed::laughing:
   / pvc vs cpvc glue #14
I'm pretty sure the purpose of the purple primer is to get all over your clothes and the wife's bathroom floor.
I suspect the people that make it also make clothing and flooring.
   / pvc vs cpvc glue #15
The color of the primer is not all that critical ... however, the color of the glue is. The colors separate different "heat" levels of the same glue (PVC) or the type of pipe being glued (PVC, ABS, CPVC). CPVC pipe is "harder" then PVC and needs a hotter glue. Grey PVC cement is much slower to "tighten up" then the clear and there are "commercial" grades that tighten up much stronger and faster. You definitely don't want to get the "red" glue they use for fire sprinkler pipe on you - it is that "hot" because fire sprinkler pipe is extremely hard.
The solvents and levels in the glues are specific to the pipe being glued. CPVC glue is for CPVC, PVC glue is for PVC - don't mix them or use them on the wrong pipe.
You can "revitalize" PVC cement by adding a bit of the primer in the glue if it is a bit thick - but if it is turning to gel, throw it out.
Many PVC fitting makers are now saying that you should NOT use the primer on 1/2" or 3/4" pipe/fittings unless they are "dirty".
Also, when gluing pipes over 1" you should hold the connection for a few seconds as the chemical reactions can push the connection apart.
BTW - Yes, I do work with PVC for a living :thumbsup:
   / pvc vs cpvc glue #16
Sell it to the local teenagers, they know what to do with it.
:laughing::thumbsup:
Yep, keeps the plumbing inspectors happy to see you actually primed it.
That's a new one to me; however, I'll continue to prime it.
I've had that happen on the smaller stuff too.
   / pvc vs cpvc glue #17
...Many PVC fitting makers are now saying that you should NOT use the primer on 1/2" or 3/4" pipe/fittings unless they are "dirty".
The primer is a softner that prepairs the PVC for the cement. It's not glue and glue should never be used on water lines under pressure. Drain lines and sprinker lines can use glue.
Cleaner is not the same as primer. Cleaner is for dirtly lines. Afer you use the cleaner, then you have to use the primer and then clear cement on PVC.
The cement melts or welds the pipe and the fittings together. Without the primer, this is not gauranteed to happen and in many cases, leads to failure.
Never skip using purple primer when working with pvc pipe. It's cheap, easy and effective!!!
Eddie
   / pvc vs cpvc glue #18
I am told that NY requires purple primer so that the inspector knows that it was used and the inspector is supposed to make you replace the affected joints if it was not used.
Aaron Z
   / pvc vs cpvc glue #19
work for a GC years ago and they had a building where the plumbers were not glueing the cpvc corectly and it was causing leaks. If memory serves it had to do with too much glue used at fittings causing the fittings to fail.
   / pvc vs cpvc glue #20
while in lowes yesterday my pops picked up a can of cpvc glue instead of pvc glue. The "ingrediants" all all the same except the last line, my question is..... Is there any real difference? will cpvc glue work on pvc? or do I have to throw it away? I have absolutely no need for cpvc.
PVC and CPVC are solvent bonded using MEK and Tetrahydrofuran in a thickened mix using PVC or CPVC resin resp to thicken the mix. The large area of joint in shear pretty much guarantees that you can use either one successfully if your temps and pressures are in range for the pipe and you let it dry well enuf before applying pressure. The bondline is microscopically thin and consists almost soley of dissolved and resolidified parent material. Altho CPVC is good to a higher temperature the bond area is so large that even a slightly softened hot bondline of PVC/CPVC++ mix would not allow the socket joint to spread.
larry
404 (A52706)
404 (A52706)
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
