Putting the driveline of cub cadet back together
   / Putting the driveline of cub cadet back together #1
Carpetbagger
various
Any of you super wrenches have a procedure or special homemade tool for compressing the heavy spring together enough to get the roll pin in and then releasing the spring? I had to take the drive line off as much of it was seized up as well as rusted together. Got the parts to replace and am now fighting the spring. Any help (advice or muscle) much appreciated. Thanks, Carpetbagger
   / Putting the driveline of cub cadet back together #2
without a picture of the problem?..
   / Putting the driveline of cub cadet back together #3
I have a tutorial on how to make a jig. It's in a thread called "what a rag" over on "Only Cub Cadets"
   / Putting the driveline of cub cadet back together #4
I guess a model number, part numbers and a photo of the problem would be a big help it use figuring out how to help you.
Richard
   / Putting the driveline of cub cadet back together #5
without seeing the problem, would a valve spring compressor work?.
   / Putting the driveline of cub cadet back together #6
It's a gear drive cub. The spring is like a 200# spring.
   / Putting the driveline of cub cadet back together #7
A dozen or so YouTube videos on methods to compress the clutch spring(s)
2006 Ford Taurus Sedan (A55853)
2006 Ford Taurus...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A57880)
2015 WESTERN STAR...
Ratchet Straps (A55852)
Ratchet Straps...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
UNUSED IRANCH IRTPL 10,000# TWO POST LIFT (GRAY) (A57193)
UNUSED IRANCH...
17101 (A55787)
17101 (A55787)
