Putting the driveline of cub cadet back together
   / Putting the driveline of cub cadet back together #1
Carpetbagger
various
Any of you super wrenches have a procedure or special homemade tool for compressing the heavy spring together enough to get the roll pin in and then releasing the spring? I had to take the drive line off as much of it was seized up as well as rusted together. Got the parts to replace and am now fighting the spring. Any help (advice or muscle) much appreciated. Thanks, Carpetbagger
   / Putting the driveline of cub cadet back together #2
without a picture of the problem?..
   / Putting the driveline of cub cadet back together #3
I have a tutorial on how to make a jig. It's in a thread called "what a rag" over on "Only Cub Cadets"
   / Putting the driveline of cub cadet back together #4
I guess a model number, part numbers and a photo of the problem would be a big help it use figuring out how to help you.
Richard
   / Putting the driveline of cub cadet back together #5
without seeing the problem, would a valve spring compressor work?.
   / Putting the driveline of cub cadet back together #6
It's a gear drive cub. The spring is like a 200# spring.
   / Putting the driveline of cub cadet back together #7
A dozen or so YouTube videos on methods to compress the clutch spring(s)
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2006 John 4 x 4 cart (A50324)
2006 John 4 x 4...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
