putting my skidding tongs to work
   / putting my skidding tongs to work #1
tawilson
Platinum Member
Theresa, NY
NH2120 RTV500 Bobcat S250 Kubota U25s
I bought some skidding tongs a month ago which I haven't found much use for yet. Easier to hook a cable or chain around the log and I know it won't slip off. Then yesterday, on a lark I tried hanging them off the loader. Worked great! I was able to slip them over the trees, move them and then slip them off without getting off the tractor. Probably an old trick but it's new to me. I set the chain so if I roll the bucket forward and let it hang loose, the chain makes the tongs hang parallel to the tractor. If I roll the bucket back, the ring on the tong hits the lip on the bucket and turns the tongs perpendicular. It was easier than I expected to pick up and drop off the logs. Those are only 16" tongs, so I couldn't pick up anything too big. Now I need a bigger set. I figure I could hang both off the bucket, depending on what I want to pick up. I thought about calling this post grappling with a problem, but too corny even for me.
   / putting my skidding tongs to work #2
That's a good use. I've also seen people hook them to 3 point hitch and use them to drag from the back.
   / putting my skidding tongs to work #4
Nice write up. Good to see a bucket that's shiny steel.
Egon
   / putting my skidding tongs to work #5
I agree. Many of those guys are pros and it really shows.
I hope one day to be half as wise as they are...
That's a good article. I go to that site a lot too. Must have tucked that article away in my subconscious for future use. Also a good point in there about the log swinging around if you tilt it up too far. I usually leave about 3' of tree on the stump after I pull it over, and the tongs makes moving the stump a lot easier. I used to fiddle around trying to get it in my bucket to save a trip off the tractor.
   / putting my skidding tongs to work #7
If I remember correctly, tongs are rated as for skidding or for lifting. I don't think skidding tongs are reccomended for lifting.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
DOUGLAS SERVICE BODY FOR SMALL TRUCK (A52708)
DOUGLAS SERVICE...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
