putting my skidding tongs to work
   / putting my skidding tongs to work #1
tawilson
Platinum Member
Theresa, NY
NH2120 RTV500 Bobcat S250 Kubota U25s
I bought some skidding tongs a month ago which I haven't found much use for yet. Easier to hook a cable or chain around the log and I know it won't slip off. Then yesterday, on a lark I tried hanging them off the loader. Worked great! I was able to slip them over the trees, move them and then slip them off without getting off the tractor. Probably an old trick but it's new to me. I set the chain so if I roll the bucket forward and let it hang loose, the chain makes the tongs hang parallel to the tractor. If I roll the bucket back, the ring on the tong hits the lip on the bucket and turns the tongs perpendicular. It was easier than I expected to pick up and drop off the logs. Those are only 16" tongs, so I couldn't pick up anything too big. Now I need a bigger set. I figure I could hang both off the bucket, depending on what I want to pick up. I thought about calling this post grappling with a problem, but too corny even for me.
   / putting my skidding tongs to work #2
That's a good use. I've also seen people hook them to 3 point hitch and use them to drag from the back.
   / putting my skidding tongs to work #4
Nice write up. Good to see a bucket that's shiny steel.
Egon
   / putting my skidding tongs to work #5
I agree. Many of those guys are pros and it really shows.
I hope one day to be half as wise as they are...
That's a good article. I go to that site a lot too. Must have tucked that article away in my subconscious for future use. Also a good point in there about the log swinging around if you tilt it up too far. I usually leave about 3' of tree on the stump after I pull it over, and the tongs makes moving the stump a lot easier. I used to fiddle around trying to get it in my bucket to save a trip off the tractor.
   / putting my skidding tongs to work #7
If I remember correctly, tongs are rated as for skidding or for lifting. I don't think skidding tongs are reccomended for lifting.
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
Kubota L3560 (A57148)
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
1994 International 3800 Bus (A54814)
1994 International...
