Putting grease in a leaking front axle?
   / Putting grease in a leaking front axle? #1
tuckybill
My Kubota L4200 is leaking oil out of the front axle wheel seal. Before I try to replace the gasket I've thought about just filling it full of grease. That would stop the leak and I don't use the FWD but in spots, no long term use where I would need the cooling effect that gear oil provides. Anyone else out there try the grease pack to keep their front FWD axle case from leaking? Any thoughts? Tucky
   / Putting grease in a leaking front axle? #2
Use "corn head grease" from the deere house . It is thinner than regular grease but doesn't leak out much. I use in my crawler tracks that used 30 weight until the seals went. It is a stop-gap measure - but it seems to protect fairly well.
rick
   / Putting grease in a leaking front axle? #3
As Rick said.. the bandaid of choice for gearboxes with leaky seals is a nlgi #0 grease.. JD cornhead is one of the more popular ones.
Obviously the right thing to do would be to install new seals ( check bearings and sealing diameters on the shaft ).. etc.. as many times a seal dieing is telling you you are getting slop in a bearing.. etc...
good luck. for intermittant use.. i imagine you will be good to go.
Might drill and tap the drain plug with a grease zerk. Be carefull to let air out as you fill.. don't want to hydraulically push the remenants of the seals out.. etc..
Soundguy
   / Putting grease in a leaking front axle? #4
Soundguy
I have seals ordered for my old B and all the seals for both sides are about $50.00. Then I should be good for another 10 years !!!!
   / Putting grease in a leaking front axle? #5
Will it work, probably but for how long and how well. The best thing to do is to repair it and use the proper lubricant.
   / Putting grease in a leaking front axle? #6
If you had any idea how many dollars worth of shafts, gears, bearings and housings made up that front swivel hub and axle assembly, you would fix it right, soon. It just isn't worth risking a parts failure due to improper lubrication. Not using 4wd makes little difference, the axle still has to carry the tractor around, and I'll bet you have a FEL on it as well. Seal replacement is relatively cheap and easy.
   / Putting grease in a leaking front axle? #7
There are probably radial ball bearings in there that won't get properly lubed unless the proper lube is in the gear cases. I don't know what #0 or JD cornhead grease is, but if it doesn't at least act like a liquid and flow, those bearings will probably run dry after a while.
   / Putting grease in a leaking front axle? #8
If yuo looke dup the NLGI specs.. you'd know that those greases mentioned are flowable greases. Lighter weights are available too.
The cornhead greas, as it's name implies was usefull as it woud reflow betweent he gear teeth when given a chance, instead of packing away from the gears and leaving a dry cavity like a #2/4 grease would/could.
Soundguy
   / Putting grease in a leaking front axle? #9
All the dealers I know that have that problem on a unit that is out of warranty put EP-0 or EP-00 in the front axle and the problem will go away for good.
   / Putting grease in a leaking front axle? #10
I think that is a band-aid approach to what is commonly a simple seal replacement. And if there is more wrong, why wait to shell out a shaft or housing to find out. Most manufacturers have moved away from gear lube to UTF in 4wd axles due to lubricity issues. Makes little sense to go the other way. Kinda makes me wonder how those "other dealers" handle real problems.
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
2022 Horizon Trailer (A55973)
2022 Horizon...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
