Putting a thumb on a KB2375 for a CK30 hst
/ Putting a thumb on a KB2375 for a CK30 hst #1
mauistardog
CK30HST
I am about to buy a CK30 HST with a loader and KB2375. I wanted to have the dealer put a manual thumb on it because I need to pick and place rocks with it. Has anyone else done this? also what is the difference between the KB2376 and KB2376 ?
I tried post this question earlier, but not sure where in went.
thanks for any help.
aloha
joe /forums/images/graemlins/cool.gif
/ Putting a thumb on a KB2375 for a CK30 hst #2
Have not put a thumb on mine....yet. The KB2376 does not have a so called sub frame, what it has is a quick connect system. with one pull of a lever, you can lift the unit ,with help of the outriggers & boom, and it comes right off the tractor.the frame for the hoe is attached to the right and left axle, the rear of tractor, and also down both sides of to the front loader. This gives you much more ground clearance and departure angle, also moves the operators seat closer to the center of tractor. The hoe itself only has around 4" clearance between the rear of tractor and the hoe unit, far less cantilevered out the back.
/ Putting a thumb on a KB2375 for a CK30 hst #3
That sounds like my new Woods hoe I just posted about. Is it a new Kioti hoe? The one that was available when I purchased my CK30 had the big mounting brackets underneath.
/ Putting a thumb on a KB2375 for a CK30 hst #4
I'm considering a thumb for my hoe also. Have you researched it to the point of having a ballpark figure for the parts and installation? Would the whole thing be less than a thousand dollars? Keep posting on this topic so I can learn from your research! /forums/images/graemlins/cool.gif
/ Putting a thumb on a KB2375 for a CK30 hst #5
What is a thumb for a back hoe?
/ Putting a thumb on a KB2375 for a CK30 hst #7
</font><font color="blue" class="small">( also what is the difference between the KB2376 and KB2376 ? )</font>
Well, maybe you mean the difference between the KB2365 and KB2376? About a foot in reach.
</font><font color="blue" class="small">( The KB2376 does not have a so called sub frame, what it has is a quick connect system. with one pull of a lever, you can lift the unit ,with help of the outriggers & boom, and it comes right off the tractor.the frame for the hoe is attached to the right and left axle, the rear of tractor, and also down both sides of to the front loader. )</font>
According to Kioti's spec site on the KB2376, it is a subframe model. What you describe is the backhoe that is made for the LK3054XS TLB unit, the sister to the LK3054XS (which is a less dedicated TLB). It is the only tractor that backhoe is now made for, has a subframe with a four point mount at the backhoe connection, but has a subframe. It's just that the subframe stays on the tractor, and as you said, doesn't interfere as much with clearance. This backhoe also has the control deck that can be tilted to or away from the operator for easier control of the levers, is easier to load on a trailer, and as you said, come off with one lever and lifting with the stabilizers and boom. It's a nice unit and I hope Kioti will go this way for all their backhoes.
John
Hi John,
No if you got to kioti.com they have a KB2375 and a KB2376.
not sure if this is just an up grade or what. I can't see any difference. they both are listed as being able to go on a CK30.
I checked out the other link to the previouse posts about the thumb. does anyone have a picture or link to a supplier? I am trying to keep is simple and go with a manual one that I just set and not a hydrolic one. I don't want to much clutter on the machine since it's not that big. Plus, I have never operated a tractor before so this will be my first /forums/images/graemlins/shocked.gif
thanks again
Joe
/ Putting a thumb on a KB2375 for a CK30 hst #9
Okay, let me try this one more time. Your post originally asked this question: </font><font color="blue" class="small">( Has anyone else done this? also what is the difference between the KB2376 and KB2376 ?
)</font>
Notice that you asked the difference between the same model number. Want to tell me which one you REALLY meant so I can tell you the difference? Thanks, John
Thanks, john,
yes you are correct. i missed typed, sorry about that.
I do have at least two questions. Has anyone added a thumb to their backhoe ? if so does anyone have picture or advise on it ?
also the kioti web site lists two backhoes one is KB2375 and the other is KB2376. Does anyone know the difference in the two?
again. sorry for the confusion. any advise is greatly appreciated.
aloha
joe
/ Putting a thumb on a KB2375 for a CK30 hst #11
Mauistardog
If you hit the search button on the top tool bar you'll find a ton of good stuff on thumbs. Might be some good reading untill you get a reply. I want a thumb too.
thanks, I went back on Don's post about a prior chat in2003 and found the link to a tumb kit at http://cdp-backhoe.com/ I printed it out and will take it to my dealer and a friend who is commercial welder to see what they think.
aloha
joe
/ Putting a thumb on a KB2375 for a CK30 hst #13
I negotiated a discount with that company for TBN members of $20 if you're interested. Look at this thread:
Discount Backhoe Thumb
About the KB2376. The website lists it for a bunch of models, but it is only for the LK3054XS TLB unit according to my dealer who looked at his order sheets to see which models it fits.
It is the one that has the one-lever disconnect that connects by 4 pts to a subrame that stays on the tractor.
The KB2375 is a regualr subframe 7.5' backhoe, where the subframe comes off with the backhoe.
John
/ Putting a thumb on a KB2375 for a CK30 hst #14
DSC_0241.JPG:thumbsup:I have a thumb attacched to my KL2465 backhoe on my CK20s. Very useful attachement, fabricated by my neighbour in his metal shop.
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
2017 International 4300 Box Truck (A62613)
2017 International...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
40' Shipping Container (A66285)
40' Shipping...
Takeuchi TL6R (A64126)
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
