Pushing With FEL
/ Pushing With FEL #21
Use the chainsaw to get the tree down and the FEL to pick up the pieces.
/ Pushing With FEL #22
OMG Southern what a You Tube. Almost unbelievable really. Guess this is another Darwin candidate
/ Pushing With FEL #23
If you must push over a tree, use the FEL to dig on the side you wish to push from, piling the dirt up as you dig. Once you have dug down a bit and exposed/broken some roots, using the dirt as a ramp, raise the FEL up a ways and push, driving SLOWLY "up" the trunk, using the weight of the dirt/tractor to push the tree down. At the same time, be careful not to run the FEL up the trunk so far as to lift your front wheels off the ground and overturn. I've done this with trees up to maybe 8-10 inches with a JD5303. If you ever watch a dozer, they pretty much use this technique on large trees.
/ Pushing With FEL #24
The easiest way we have found to clean up after an ice storm is with high lift or extending boom fork lift. the one we used last time would go up about 75' and it had a grapple attachment that would allow you to grab the limbs that were broke off.
/ Pushing With FEL #25
If your tractor has hydro you can raise the bucket, keeping the leading edge in line with the pins and lift the front wheels off the ground getting a little more leverage. You can then bounce things a little bit to see if the tree is starting to move. Don't try this with a clutch tranny or without a solid roof on your ROPS.
Once the tree starts to shift you can decide to dig some more or push harder.
I'd still just clean up what you have to now, then wait for spring to see what survives. It will be safer and easier to finish when things are warmer.
/ Pushing With FEL #26
I am pretty sure you are going to have plenty of broken limbs to deal with before you have time to remove trees.
I have family in both Harrison and Gassville, they have told me what it looks like, your pictures confirm the mess. What ever you do DO NOT do what this guy is doing... YouTube - Tractor Catastrophe!
KennyV
/ Pushing With FEL #27
KennyV
Boy, that guy got lucky!
/ Pushing With FEL #28
I always cut down my trees 5' off the ground. I then come back with my FEL and push North, South, East, West when the ground is wet then pull out the whole thing by putting a chain at about 4' off the ground and pulling from the draw bar.
Chris
/ Pushing With FEL #30
I had to post these. A friend knew these people. And believe it not nobody was hurt. They guy manage to jump out the back end before the tractor got crushed. His brother was on the other side of a hill when he heard something and when he got there the guy using the TBL was laying on the ground. Guess he was digging around the tree to knock it over.
Oh this was back in the fall and the TBL is put back together and in use. I guessing a little more carefully now.
Wedge
/ Pushing With FEL #32
Good advice but your time line is off a bit. He lives in Northwestern Arkansas. The weather in that part of the country is Ice Storm today high 60s tomorrow. Since the ice storm he has had several days of mid to high 60s weather. He probably wont have to wait until spring to finish.
/ Pushing With FEL
KennyV
Gads. That was an exercise in demonstrating a lack of common sense.
/ Pushing With FEL #36
When I'm pushing on trees trying to get them down, my limitation is the tractor. The wheels will slip or the tractor will bog down or start climbing the tree. I haven't damaged the fel in the four years of doing that. Don't know if the recommended fels for different tractors are matched like that or not.
Here is a picture of my son testing the limitations of the L4400 HST. The trick is getting the tooth bar undeer the root ball. That is a wild cherry tree. Oh and it also helps if you let the wind blow it down first.LOL
/ Pushing With FEL #37
I would say that a tractor would work fine on smaller live trees. If you slowly push with the bucket elevated, you get more leverage on the tree. Once the tree begins to fall over...the weight of the tree itself helps it to continue it's fall. The good part to using the tractor then, is that the root ball is exposed and half uncovered.You can then push and curl the rootball out. No more stump to trip over.
Bigger trees need the chainsaw. Make a wedge cut, then a horizontal back cut on the other side of the tree a few inches above the wedge cut to fell the tree. The wedge cut opening will point the way you want the tree to fall. If you are afraid of lean...use wedges in the horizontal cut to slowly lift and move the tree to make it fall where you want. Make sure your tractor and stuff is parked beyond the tree! I don't think I would tie any rope or chain from the tree to the tractor, since the tree may fall the wrong way...and there goes the broken half of your tractor drug across the yard.
Don't mess with a dead tree except with a chainsaw. If you start to pushing on one the dead limbs and possibly the upper trunk may break off and dent your tractor and your head! And wear a helmet!
/ Pushing With FEL #38
I'm sorry to see the damage you sustained during the last ice storm. But this damage is minor compared to what might be in store using a wheel tractor to push over damaged trees. Without proper ROPS, (forest rated ROPS are different than agricultural ROPS rememberand much safer too) you could be looking at serious injury! I've been in the wood business for many years along with my dad and have done many-a-dumb stunt but its is terribly dangerous. May be old age is getting the best of me : If it were me doing the cleanup I would use the tractor to push brush away from the tree first to come down and then fire up the chainsaw and work one at a time making sure I had a way out before cutting the next tree. I broke my ankle and foot when I couldn't get away from a falling tree fast enough, injurys make the job tougher, especailly when you have to is work. You really do have a mess on your hands, but if you attack it slowly and one at a time planing as you go you should be all set. Remember a 90' tree has a lot of leverage on a little tractor 9' up on its stump, no need of spending extra hours and money repairing your tractor and your treescapes. John
/ Pushing With FEL #39
Agree with all of those suggesting caution in these exercises and the limits of a tractor for such work. A LONG rope can certainly be useful in guiding a tree down, a snatch block is also very useful so that you aren't pulling the tree towards you. Beware of loose branches in other nearby trees as they can be shaken/knocked loose and fall in a lethal fashion. Be very aware of wind forces and of the direction the tree "wants" to go by gravity - either slope or lean.
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
12x20 Car Port (A65640)
12x20 Car Port...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
