Pushing over cedars
/ Pushing over cedars #1
txloops
Is there a "right way" to push over small trees with a tractor/FEL? The dealer said you can do it....but didn't explain HOW. I'd appreciate any tips...want to be productive but safe.
/ Pushing over cedars #2
With my small Kubota, I bring the loader bucket up about 4 ft off the ground, put the tractor in low, roll up and stop with the bucket just touching the tree, hit the differential lock, and press the hydro pedal all the way down. Usually it will push over a tree about six inch diameter at the base, but not a six inch Florida Pine. Once the roots have pulled up a little on the side where the tractor is, I dig down a few inches with the bucket, used the same procedure to push forward, but curl the bucket up after it goes under the roots. Repeat these two steps a few times and most small trees come right out. With a tree that has a real deep root ball, I've been digging around with the backhoe a little before I push it over.
I don't know if there's a right way or not. Just go with trial and error, without beating up the tractor. In other words, no full speed ramming action and you should be OK.
/ Pushing over cedars #3
txloops,
Welcome to TBN.
I do pretty much what aardvark is recommending (although I don't have cedar).
Please fill out your profile when you get a minute so we know what type of tractor and "stuff".
To elaborate on a couple things:
I don't have hydro. If you have a gear driven tractor, put it in it's lowest gear and have the RPM's up a little when you go to push.
Be careful if the tree is dead. If/when it comes back, the top can snap off from the rocking and come down on you and/or your tractor.
When using the bucket to push on the tree, try to keep the bottom of the bucket perpendicular to what you're pushing on. If you put the bottom (flat side) of the bucket flat against the tree, it may bend your bucket.
When the tree goes over, watch the root ball on the near side. Depending on the diameter of the root ball, it'll sneak up under your tractor. You don't want to get hung-up nor have the roots damage something in the front or undercarriage of the tractor.
Brian
/ Pushing over cedars #4
Be careful not to back up with the cedar or any tree under the tractor where the limbs may catch your hoses or get under your tractor hood and break it. Tree limbs under the tractor can do damage if they get lodged while backing up.
/ Pushing over cedars #5
<font color="blue"> "... and press the hydro pedal all the way down. Usually it will push over a tree about six inch diameter..."
<font color="black"> Gear guy myself but doesn't pushing the hydro pedal increase the gear ratio which would reduce the pushing force?
John
/ Pushing over cedars #6
</font><font color="blue" class="small">( doesn't pushing the hydro pedal increase the gear ratio which would reduce the pushing force? )</font>
Yes, and if you do it quickly you can stall the engine. If you do it slowly, you'll either go, or spin the wheels, or hear the engine bog down a bit and a relief valve will open without killing the engine. At least that's the way it worked on both my Kubotas.
/ Pushing over cedars #7
Thanks. Sounds like Jared has power to spare.
/ Pushing over cedars #8
Not too much power to spare, I just live in a sand pit, also known as south Florida. /forums/images/graemlins/smile.gif The soil is so sandy down here, most stuff comes out really easy.
Also normally I press the pedal down pretty slowly, it's not a "stomp on the pedal" procedure. If the pedal is all the way down, the root ball is on it's way out and I'm keeping the tree moving the direction I want it to go. That, and the BX23 low speed selection seems really low, but I haven't really used many other tractors to compare it to. I guess I wasn't clear in my first post, should have thought it through a little more.
Thanks to all for the replies and advice. This site is proving to be invaluable to a "newbie" tractor owner. I don't have Hydro on my tractor...but I understand the differential lock and slow approach.....sounds like a plan!
/ Pushing over cedars #10
We live in a hilly area of rock, swamp and hardwoods and seem to be forever building trails for skidoos or 4wheelers. It is a lot easier to push atree out, roots and all than cut it off and then dispose of the stump. I have found that if you can get a tree to rock and move a bit at the roots, you can normally push it over. The secret is to remember that the higher on the tree you can push, the more leverage you have. Each time you rock it, a few more roots break. Sometimes you have to remove a bit of dirt with the FEL and sometimes you have to turn around and pull with a LONG strong rope, tied as high as you can reach. It also makes a difference if the soil is dry or wet and what kind of tree it is. Poplar and cedar tend to break off if pushed too hard, birch tend to drop branches on you and oak is a real challenge. Most maples in our area (less than 12" dia) come out fine. Pat
WOW....i will certainly be careful......i like the long rope or chain suggestion.
/ Pushing over cedars #13
As a retired safety guy I feel the need to comment. All the suggestions are very valid and this can be dangerous. I have many cedars on my property that I remove with the tractor.
A special caution when using a rope to pull anything. Make sure the rope has a high breaking strength. Unfortunately I have seen men cut in half and limbs severed when a rope breaks and whips back. This is especially likely to happen with synthetic ropes. If the rope seems to be stretching a lot and the diameter is getting thinner this is a sign to slack off on the pull, If you can find them ropes that have a "static" rating are safer, up to their load limit.
/ Pushing over cedars #14
Not many folks would use a rope for pulling. I know there is specialty rope made that can withstand the stress of pulling a tree out by the roots, but it would certainly be special order where I do my shopping. A safety rule of thumb is to make sure your chain/cable/etc is not the weakest link in your pulling asembly A smart rig will have the tractor's ground traction the weakest link. I use 3/8" or 5/16" Grade 70 transport chain and hook assembly for all my pulling and lifting with my 4110.
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A66736)
2021 Chevrolet...
2015 Infiniti QX60 (A66738)
2015 Infiniti QX60...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
2020 KOMATSU PC360LC-11 EXCAVATOR (A65056)
2020 KOMATSU...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2006 KENWORTH T800 TRIAXLE (INOPERABLE) (A67714)
2006 KENWORTH T800...
