Pushing out with FEL
   / Pushing out with FEL #21
It was, even while winching her out the wheels were more like plows. Ground was like a marshmallow once it broke through the top crust:)
   / Pushing out with FEL #22
I got stuck with my 3038 the other day where my driveway drops off quick. With My old Kubota B8200 I could put the FEL all the way to dump, drop straight down and curl the bucket to push the tractor back out. I tried that with the Deere and curling the bucket wouldn't do it. Just chattered. Once I got unstuck I tried it in the drive. I found if the bucket was fully dumped - slighty past verticle - the result was the same. When I payed attention to the angle of the bucket in the dump position and only brought it to verticle it would move the tractor backwards.
I didn't think there would be a point of dimmishing returns on the hydraulic cylinder if I brought the bucket past 90 degrees. Anyone else experience this?
I have a 4310 with a 430 loader and it has done the same all the time I have owned it. The bucket edge cannot be past vertical.
   / Pushing out with FEL #24
If it's past vertical it has to lift the frontend to curl. My 3120 is exactly the same. Don't worry about it.
   / Pushing out with FEL #25
I have used the FEL on both my NH and JD to pull myself out going forward and / or backward..Going forward I just lay the bucket down flat and then move it into the dump mode with down pressure and it will pull me out going forward...takes a number of times but I get out....and backward I put the FEL down with pressure in the full dump mode and then curl and walk it out that way...again it can take a few times...
2024 Electric Intimidator UTV (A59814)
2024 Electric...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60460)
2017 Peterbilt 567...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
