Pushing out with FEL
   / Pushing out with FEL #11
I have a 3038 and am wondering how you got stuck and how you got it out. I assume you were in 4WD. Did you tap the brake to lock the rear differential?
I thought I was stuck a few weeks ago while trying to dig down into damp clay. I have R4's. I was in 4WD and was spinning the tires while trying to back out of the hole with a full bucket. After I locked the rear, I just let it spin and it slowly dug in and backed out.
I decided that my tractor just too traction limited with R4s to attempt that kind of work.
   / Pushing out with FEL #12
R4 in clay mud = useless!
The 3720 has been stuck multiple times along with the skidsteers and the curl technique always works. Have you reported the situation to Deere? :confused:
No, I haven't. You're right, I will. I was chalking it up to 'operator error'. It shouldn't be the case.
"I have a 3038 and am wondering how you got stuck and how you got it out. I assume you were in 4WD. Did you tap the brake to lock the rear differential? "
Yup, 4wd, low range, differential locked. The position I was in only allowed traction for 1 front and 1 rear wheel to be in contact with the ground - teetering. It was the first snow of the year and I escaped by driving forward and out through the field. Ain't gonna happen now with 2 feet on the ground.
   / Pushing out with FEL #15
I may be in the minority, but my finding is the same as you. I can't move the tractor from a full curl (deere 3120, 300cx loader). I assumed it was just a function of the loader geometry. If I don't do a full curl, but just to where the bottom of the bucket is vertical, it will move the tractor. It should be said, generally, I manage to really stick it. Last week, I managed to slide downhill and after some maneuvering, had the front wheels in mud over the center hub, and another 2 feet of snow. After making a mess, I was able to get out. Let us know what you find out from the dealer. Thanks.
Jon Hunter
   / Pushing out with FEL #16
I've notice on my L w/bucket at full curl just doesn't seem to have power to push back,but 2/3 curl or less not problem...more than enough press to pick front tires off ground tho.
   / Pushing out with FEL #17
Please let me know if you find this true after your little tire grooving experiment. If in fact you find that it is indeed quite advantageous, i will be attempting this project asap.
   / Pushing out with FEL #18
My experience with traction or lack there of, has been lack of tractor weight. The thing is to light to get any traction. I put Michelin Tires on the back and that helped tremendously. They clean and bite very well. Then I added 750lbs of weight on the rear and that has really made a big difference.
   / Pushing out with FEL #19
I was able to unstick mine by curling, but then the rears fell in and I successfully curled my way to the bottom. :) don't worry she looks like new again:)
   / Pushing out with FEL #20
Wow, that looks like a tough field to stay up on top of.
2020 DRAGON ESP...
2020 DRAGON ESP...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
Toro Utility Cart (A59228)
Toro Utility Cart...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2013 NISSAN NV3500 CARGO VAN (A59575)
2013 NISSAN NV3500...
