Pushing John Deere 425
/ Pushing John Deere 425 #1
a.palmer jr.
I have a 425 John Deere tractor which I'm needing to move. The engine is being worked on right now so it isn't running. Is there any way to move this tractor?
/ Pushing John Deere 425 #2
There is a lever inside the right rear wheel against the frame that lifts up to disengage the transmission. Then you can push it.
Chris
/ Pushing John Deere 425 #3
One should check the owners manual once in a while. Alot of useful information including moving the tractor without starting the engine. I'm as guilty as the rest until there is a problem. Good luck.
/ Pushing John Deere 425 #4
How is this reply helpful in anyway? Maybe he doesn't have a manual for it.
/ Pushing John Deere 425 #5
I agree, give the guy a little slack
/ Pushing John Deere 425 #6
Yup, we can be here to help, and be happy doing it. :D
/ Pushing John Deere 425 #7
JD has excellent resources on their website. If the OP doesn't have a manual he can find it on John Deere Home Page Redirect . The LT/GT owners & parts manuals are available under the "Residential Equipment" tab, then go to "Services & Support." Owners manuals are found at the top under "Technical Publications." This resource can be a lot of help if you've lost your manual or bought a used machine without an owners manual.
I didn't get an owner's manual with the tractor. I bought it used, but thanks to those who did help. The little bar behind the right rear wheel was well hidden, but worked and I finally got to move the tractor to where I could clean the engine compartment while engine is out.
The reason I asked in the first place was because someone told me you couldn't move the 425 or you'd damage the trans. I thought as expensive as these things are they should have made a way to pull them. I'm glad I asked.
2015 GMC SIERRA 3500HD (A67714)
2015 GMC SIERRA...
2018 MACK LR 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR 6X4...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2006 Freightliner M2 112 T/A Wet Kit Day Cab Truck Tractor (A66736)
2006 Freightliner...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2007 (INOPERABLE) INTERNATIONAL DURASTAR 4300 (A67714)
2007 (INOPERABLE)...
