Push or pull?
/ Push or pull? #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I'm talking about caulking guns of course. My dad who was a professional construction painter taught me to always push a caulk gun. What do you guys do?
/ Push or pull? #4
Pushing causes the caulk to penetrate deeper into any void areas.
/ Push or pull? #6
Pushing doesn't feel as natural but will give a better fill and smoother finish.
/ Push or pull? #8
push usually, depending on what I am caulking.
/ Push or pull? #9
I pull but finish up by running over the caulk with a finger. Finishing up with the finger gives a nice, smooth finish and also helps to push the caulk into where you've caulked.
Ralph
/ Push or pull? #10
I generally mask the area to be caulked, squirt it into place whatever way is easiest, smooth it out with a finger or properly angled scraper, and peel the tape off before it sets up. Gives a nice professional, nearly machine applied type of finish without much practice, effort, or learning curve.
/ Push or pull? #11
I hung wallpaper for about 15 years. Most of the time I pulled - partly for a nice even bead and partly for speed. After applying the bead, I used a "wet finger" to smooth. Keep in mind that I cut the tube on an angle way down the tip so that the opening was very small. When I was finished I had a nearly invisible bead that held the edge of the paper down, filled the gap and looked really finished.
Once you develop a technique that works for you, it is hard to change to another style/method.
/ Push or pull? #12
A trick I learned about and tried that works.
To create a nice finish you draw an ice cube along the calk seam.
It of quite a good trick for those that difficulty with the other methods.
Personally I am capable of the either push or pull technique but probably use the pull with a good bevel cut more often followed with the wet finger.(and a handy rag to wipe the finger)
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
2006 Chevrolet TrailBlazer SUV (A64557)
2006 Chevrolet...
