Push or pull?
/ Push or pull? #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I'm talking about caulking guns of course. My dad who was a professional construction painter taught me to always push a caulk gun. What do you guys do?
/ Push or pull? #4
Pushing causes the caulk to penetrate deeper into any void areas.
/ Push or pull? #6
Pushing doesn't feel as natural but will give a better fill and smoother finish.
/ Push or pull? #8
push usually, depending on what I am caulking.
/ Push or pull? #9
I pull but finish up by running over the caulk with a finger. Finishing up with the finger gives a nice, smooth finish and also helps to push the caulk into where you've caulked.
Ralph
/ Push or pull? #10
I generally mask the area to be caulked, squirt it into place whatever way is easiest, smooth it out with a finger or properly angled scraper, and peel the tape off before it sets up. Gives a nice professional, nearly machine applied type of finish without much practice, effort, or learning curve.
/ Push or pull? #11
I hung wallpaper for about 15 years. Most of the time I pulled - partly for a nice even bead and partly for speed. After applying the bead, I used a "wet finger" to smooth. Keep in mind that I cut the tube on an angle way down the tip so that the opening was very small. When I was finished I had a nearly invisible bead that held the edge of the paper down, filled the gap and looked really finished.
Once you develop a technique that works for you, it is hard to change to another style/method.
/ Push or pull? #12
A trick I learned about and tried that works.
To create a nice finish you draw an ice cube along the calk seam.
It of quite a good trick for those that difficulty with the other methods.
Personally I am capable of the either push or pull technique but probably use the pull with a good bevel cut more often followed with the wet finger.(and a handy rag to wipe the finger)
2008 Ford F-350 Crew Cab Emergency Service Truck (A64556)
2008 Ford F-350...
Beverage Truck Body (A64556)
Beverage Truck...
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
1997 International 3800 School Bus (A64194)
1997 International...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
