Purchasing a New UTV
/ Purchasing a New UTV #21
With the weather (lately) in Texas, you might consider something like this 😆
Gator XUV 835r
/ Purchasing a New UTV #22
I guess in order of importance for me, the question would be:
How much time does it take to install and remove them?
How durable are they?
Are they prone to freezing up? If parked in an unheated building.
How much power do they use (rob) to operate? Do you need to operate in low (on a Mule) or will you smoke your belt.
How much do they cost?
/ Purchasing a New UTV #23
How much time does it take to install and remove them? An hour or 2 after there first installation.
How durable are they? If you used them in snow, the tracks are quite durable. I rarely run them on any dry ground and don't recommend runnig them in dry land. The bearings Camso uses in theirs bite.
Are they prone to freezing up? If parked in an unheated building. I leave mine in freezing temps all the time. No problem
How much power do they use (rob) to operate? Lots in snow. Our 800cc engine has marginally enough power on 1600lbs machine.
Do you need to operate in low (on a Mule) or will you smoke your belt. Yes in general but while ferrying on hard, easy going surfaces, would go to high.
How much do they cost? Depends on which ones you are speaking of???? 4 to 7K.
/ Purchasing a New UTV #24
Interesting. Thanks.
I suppose it's often a case of do you NEED to get somewhere through snow, with some carrying capacity?
Or, as in my case, I wouldn't mind getting to parts of the property in the winter, but don't have too. So the bother of Re&Re and COST comes into play.
I had an eight wheel Diesel (factory prototype) amphibious ARGO with tracks. I thought my life would be perfect after that, but it was a bit of a let down, for a few different reasons.
/ Purchasing a New UTV #25
I'll defer to Arly, I've only had the machine since January but so far I'd have to agree. (y)
/ Purchasing a New UTV #26
I've learned that the individual mounting kit's (proper lug pattern hub, anti rotation hardware) is available to fit a used pair to your machine. I've seen them quite often on c/l for $2500-3500. I believe that they (Camso) have 2 basic models, quad/atv and utv. There's an outfit called atvtracks.com on youtube that has some helpful mounting, adjusting, and operating videos.
/ Purchasing a New UTV #27
I've been operating ATV's and UTV's with pods on and in snow for many years and for thousands of hours. Here is my personal machine. What can I say, but I love these machines....
/ Purchasing a New UTV #28
One trouble with the ARGO was the temendous amount of power needed to turn an 8wd long vehicle in snow. Push all that snow sideways. The Dif/disk brake transmission was not up to the task.
/ Purchasing a New UTV #30
I saw the owner of ODG playing with this Diesel prototype (Rugarini 2cyl air cooled) at an Enduro, and hounded the poor man relentlessly for years until he sold it to me.
The charging system was inappropriate on the OEM engine to run the cooling fan for the brakes so I put on a GM alternator, but that required more revs at idle, engaging the snow mobile clutch, or making it impossible to engage the gears. Not ODGs fault. I bought it AS IS.
I wish I still had it, but sold it at considerible profit and helped pay for the 2001 Mule 2510.
The most fun was taking an unsuspecting person for a ride and making a quick unexpected turn into the pond!
/ Purchasing a New UTV #31
That had to have been one of the older style work Mules like a 4010 which do. ride pretty rough.
Curious what are the disadvantages of having a CVT belt?
Belts come off when you it most inconvenient.
/ Purchasing a New UTV #33
My Dad made a financial contribution towards the Mule. After I got it, I took him on a jaunt around the farm with maybe four inches of snow on the ground. After a while, I could smell the belt smoking. Switched to low.
Changing the belt on my Diesel 2510 is not a job I would wish on anyone.
I gotta say. I simpy HATE campact or some other equipment where you simply can't get at anything.
/ Purchasing a New UTV #35
Kind of like trying to change the drivers side low beam bulb on my 08 Sierra. GM basically says to take the front of the truck off! They "could" have made the process easy, but elected not to.
/ Purchasing a New UTV #37
Gee guys, we change the belt when we take it in for its oil change. :rolleyes:
Since '06 the belt on my EZ-GO has outlasted the original engine. (replaced that in '16)
I've had too many cars (Camaro, others) whose front light bulbs are replaced by pulling back the poly fender liner and working from the wheel well. My '11 Mazda 6 is the same way.
btw, with my Mechron I keep bumping the light switch to 'on' when getting out.
/ Purchasing a New UTV #39
Some more pictures of that second enclosed rig in snow would be appreciated.
I would love to know some experience of the early Mule 2510 Diesels and peoples long term experience/costs. My 2001 doesn't have a thousand hours yet. No one ever mentions a word about the costs associated with ATVs. Just how great such and such is and what they use them for.
/ Purchasing a New UTV #40
Good chance that's a Can-am (Bombardier) Defender. If you check out the Facebook site "Can-am Defender Nation" you'll see a lot of photos of those things wearing tracks. Seems to be the thing up in Canada. This is my Defender with the factory cab and heat:
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
1980 19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A64557)
1980 19ft Sailboat...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2017 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 INTERNATIONAL...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
