Purchased Dougherty Turbo Saw (3 point) - First Experience with Video
   / Purchased Dougherty Turbo Saw (3 point) - First Experience with Video #41
I am running the turbo saw on a John Deere 3038E. I am at the bottom end of power for using the saw. When the saw blade binds, It stalls the engine. The slip clutch needs more power to engage than my tractor 's PTO can supply. I have never had a problem with pulling the blade out of a cut. The pulling power of the tractor should be able to pull out of any cut that the saw can make.
   / Purchased Dougherty Turbo Saw (3 point) - First Experience with Video #42
Caution...Update... I purchased a ratchet allen wrench and was able to break free the blade tips today and I have to say it worked much better. If I had used the ratchet wrench in the first place instead of just an all allen wrench set it would made my life a lot simpler. I also experimented with my cutting technique and was much more successful with the saw. The key was to keep the saw in the lowest gear ("A" for my John Deere) and saw much slower speed than when I was using the medium or "B" gear. That way I can keep the PTO speed high while cutting. I did not see either of these comments on the you tube reviews but it made all of the difference in the world. I cut more than 50 large cedars today, many with trunks of up to 12-inches in diameter. Our property is overrun with large cedars and is in desperate need of habitat improvement. In the end, it was probably more a case of operator error and I hope nobody has to retrieve their saw from their boats.
   / Purchased Dougherty Turbo Saw (3 point) - First Experience with Video #43
Bring an old thread back to life rather than repeating.
   / Purchased Dougherty Turbo Saw (3 point) - First Experience with Video #44
Old machine shop secret 101.....
Always use anti seize compound on the screws that hold cutting inserts to the cutter body.
My favorite was the copper color compound.
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
2006 Grove TMX25 (A55973)
2006 Grove TMX25...
1459 (A57192)
1459 (A57192)
