purchase Rain flapper ?
/ purchase Rain flapper ? #1
ourfarm
Hi;
Where do you buy your exhaust rain flappers?
I would like to buy or build flappers for my tractor and
diesel generator(under construction).
Anyone build any from scratch?
Any photos or links to photos with good closeups ?
Thanks
Ourfarm
http://ourfarm1.home.mpinet.net/index.html
/ purchase Rain flapper ? #2
I bought mine from Tractor Supply Company. They had an assortment of sizes for different diameter exhaust pipes.
/ purchase Rain flapper ? #4
Hey shoppintractors...
Really embarrased how that basketbrawl game came out...
especially since the Pistons originally came from right here in Fort Wayne,INDIANA!!! (Fort Wayne Zollner Pistons) LOL
/ purchase Rain flapper ? #5
ourfarm,this is just a personal opinion,but,you might consider using a exhaust turnout instead of a flapper,after 25 years of hearing those flappers on tractor trailers (i'm a mechanic) constantly clap,clap,clapping at idle i don't ever want to hear it again!! plus a turnout can be rotated to point the exhaust fumes away from you.just a thought!
/ purchase Rain flapper ? #6
I bought mine from TSC. It lasted about a week, and when it fell apart, I was so happy for the silence again, I never replaced it.
I like the idea of turning the pipe out instead of a flapper. The noise will just drive you crazy!!!!!!
/ purchase Rain flapper ? #7
There's always the trusty coffee can!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ purchase Rain flapper ? #8
</font><font color="blue" class="small">( after 25 years of hearing those flappers on tractor trailers (i'm a mechanic) constantly clap,clap,clapping at idle i don't ever want to hear it again!! )</font>
i always liked that, sorta a heavy duty sound, i even used to have a lawn tractor that had a flapper on it
/ purchase Rain flapper ? #9
I had added flapcaps to all my verticle exhaust tractors, and kinda liked the rattle a bit. I think I got mine from TSC. However my latest tractor.. a 7610s.. has a turnout permanently installed, so After i park it under the shade structure.. I also use the 'can' route
Soundguy
/ purchase Rain flapper ? #10
ourfarm:
I purchased one from tractor supply for my NNA, the flapping drove me more nuts than I already am so I drilled a 3/8" hole in it and added a 3/8" bolt and enought washers to counter balance it, now it works great and doesn't make any noise!
Thanks for all of your input.
My tractor has the stack angle cut at the top but I did not
think that it would keep water out in the direction of the cut.
After a lot of your replies I was going to forget about the
flapper but after Mansker's reply I may try it anyway.
I have not decided on a exhaust for my diesel Generator yet
Ourfarm
East Central Fla.
/ purchase Rain flapper ? #12
how often do you plan on usi8ng the generator?
if it is running chances are it won't be at idel anyways so adding one won't be hard
I had a angle cut on my tractor when I got it but it pointed at the FEL hyd lines/arm when it was raised up. I cut it off and use a pop can cut of and if I park it outside it goes on, if it is running and raining the rain will not get in anyhow and if I forget to remove the can it blows right off.
anyhow good luck.
Makr M /forums/images/graemlins/smile.gif
/ purchase Rain flapper ? #14
??? why not?
Soundguy
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
Rotomec Auger (A64127)
39' 9" 3 Bar Drag Tooth Harrow (A66285)
39' 9" 3 Bar Drag...
Skid Steer Rock Digger (A65640)
Skid Steer Rock...
